Cooked plug wire
Old Aug 16, 2015 | 06:34 PM
mtntop1's Avatar
mtntop1
Cooked plug wire
I installed shorty headers on my 95 F150 302.and #4 spark plug is close to the header tube.I tow a 4000 lb travel trailer and when I tow up hills #4 spark plug wire boot will burn through and will misfire.I have installed boot protectors (1200 degrees) and header wrap but still have the same problem.This only happens when towing up hills.Is there anything else I can do.The engine temp is normal.
Old Aug 16, 2015 | 09:19 PM
FordTruckDoc's Avatar
FordTruckDoc
Are you sure the exhaust isn't leaking a little in that area? Maybe check that with some seafoam, or use a laser thermometer to compare temps at different points across the manifold.
Old Aug 17, 2015 | 09:16 AM
timbersteel's Avatar
timbersteel
Agree^^^^
Could be #4 running lean.
Old Aug 17, 2015 | 09:29 AM
'89F2urd's Avatar
'89F2urd
Pic of header and plug
Old Aug 17, 2015 | 09:54 AM
mtntop1's Avatar
mtntop1
Originally Posted by timbersteel
Agree^^^^
That's what I'm thinking but why only #4
Old Aug 17, 2015 | 09:57 AM
'89F2urd's Avatar
'89F2urd
#4injector isn't firing right.
Post up a pic, it could be an instance where it's a poor design and nothing you do will stop it.
Old Aug 17, 2015 | 11:17 AM
mtntop1's Avatar
mtntop1
A pic of area
Rickzap
Dec 25, 2015 03:00 PM
ZonaNavyStar
Aug 25, 2007 11:26 PM
reedy d
Jul 10, 2007 06:16 AM
caesarnapolitano
Electrical Systems/Wiring
Feb 13, 2006 05:06 PM
boilersouth_2002
Jan 16, 2004 03:15 PM
