SCT livewire problem & question
Old Aug 16, 2015 | 03:24 PM
bobv60's Avatar
bobv60
I just purchased a livewire TS and the exhaust backpressure is not reading correctly. I DOUBLE checked and all the scales are off, PSI, KPS, BAR MMHG, INHG, ect. I did a search and there a quite a few posts on different forums about the same issue so it is a common problem, but I don't see any resolution anywhere. I did go online and update the livewire before install. Any one know if there is a fix?
I would also like to know if I select the option to shut off the EGR does it actually shut off the EGR? Or does it just shut off the CEL from coming on if the EGR is deleted?
THANKS
Bob V
Old Aug 17, 2015 | 08:09 AM
evan1242's Avatar
evan1242
give SCT a shout.
they are typically pretty good in there tech support department.
JRD761
6.7L Power Stroke Diesel
Jan 10, 2016 08:58 PM
kel1306
Oct 3, 2013 04:05 PM
lwk362393
New York Chapter
Jul 16, 2013 08:44 PM
2010F350
6.4L Power Stroke Diesel
Oct 17, 2010 04:36 PM
eric777
Sep 1, 2009 09:24 AM
