New Process 435 leaking
Old Aug 12, 2015 | 11:49 PM
78F-250/4x4's Avatar
78F-250/4x4
7th Gear
So I have a lil bit of fluid that drips from my NP435 and 205 t/c. Thinking of just getting rebuild kits for them to overhaul, or should I just find where the leak is and fix it. Also, what type of oil do I out in them? I am assuming a gear oil, just not sure of any specifics.
Old Aug 13, 2015 | 07:21 AM
OldOrange's Avatar
OldOrange
I would find the leaks first and fix them. It's probably the input seal in the transfer case. Right where the transfer bolts to the transmission. In my experience that's where most leaks have occurred. As far as oil I ran 80/90 weight in both my np435 and 205 transfer.
Old Aug 13, 2015 | 07:49 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Do they need a complete overhaul? Might as well if you have to pull them to get to the leaking seal. Especially if you have to slit them.
But if it is just a output flange seal, that is a quick deal. X2 on 80/90.
Towerrider87
Aug 10, 2017 07:23 AM
crucialprospect
Mar 4, 2017 08:05 AM
CaptainFacePunch
Jun 13, 2015 01:55 PM
idahodisco
Mar 10, 2010 11:10 AM
spudgunman
Feb 6, 2010 03:37 PM
