Sponsored by: Real Truck
2002 Ford F-250 5.4l misfire
Old Aug 12, 2015 | 05:12 PM
Dark_knight's Avatar
Dark_knight
Hey guys, so basically I thought it would be a great idea to degrease my motor from the top down.... After washing I start it up and drive down the road to head abunch of misfiring under heavy load or high rpm's.
my problem is that the misfiring won't throw a code. I then proceeded to buy a new ignition coil (thinking this was the problem) but with no code to go off which cylinder was bad I just switched the good ignition coil into each cylinder and starting it
Up each time. None of them seemed to make it better. Also the injectos all seemed to be good. So if anyone has any idea on what to do I would appreciate the
help. Thanks!
This is the beast
Old Aug 13, 2015 | 10:14 AM
octaneforce's Avatar
octaneforce
I did this once and ended up ruining my mass air sensor and an o2 sensor. no code is peculiar though.
Old Aug 13, 2015 | 11:48 AM
Dark_knight
Did you have the truck running when you did that?
Old Aug 13, 2015 | 11:59 AM
octaneforce
yeah. what happened was my radiator cracked open while i was driving and i sucked in a whole bunch of coolant. i understand your problem is a little different lol.
mfp4073
1983 - 2012 Ranger & B-Series
Jun 17, 2014 02:38 PM
graydonricker
1997 - 2003 F150
Sep 16, 2011 09:35 PM
pageparsley
Modular V8 (4.6L, 5.4L)
Jan 14, 2006 08:46 AM
RobbyMartin
Nov 30, 2005 07:17 PM
captron904
Jul 9, 2003 12:39 AM
