Sponsored by: Real Truck
tpms delete
Old Aug 12, 2015 | 12:51 PM
octaneforce's Avatar
octaneforce
tpms delete
am I the only one who thinks the tire pressure monitoring system is a silly feature? is there anyway to delete this and stop the light from coming up on the dash? I want to do new wheels and tires on my 2008 f250 and I don't want to deal with the tpms. can it be tuned out from the computer? what tuners are you guys using? I know its a work truck! lol! thanks!
Old Aug 12, 2015 | 04:46 PM
fishbones182's Avatar
fishbones182
tpms delete
Yes the system is absolutely dumb. No matter what tuner or time you can not disable it. The system Ford used is worthless. There are others that at least give you the pressures in all 4 tires so you at least know the low tire in the event it's not a complete flat rolling down the road. If you find a way let us know I'm sure the vast majority all feel the same way about it.
Old Aug 12, 2015 | 06:13 PM
NYCruiser's Avatar
NYCruiser
Yeah, it sucks. I figure the bulb will burn out eventually.
Old Aug 12, 2015 | 06:24 PM
seville009's Avatar
seville009
I have tires on without the tpms valves. The warning only goes off maybe once every two or three weeks.
Old Aug 12, 2015 | 06:45 PM
xr7gt390's Avatar
xr7gt390
TPMS is a federal law & is part of the Federal Motor Safety Standards. I doubt anyone will want to disable these systems because the liability costs could be high. The system is getting better with each passing year but still leaves a lot to be desired.
Old Aug 12, 2015 | 06:52 PM
Army RET's Avatar
Army RET
Count me as being contrary; I find TPMS useful and much appreciate them keeping an eye out for me (as I no longer need to check tire pressure).
Old Aug 12, 2015 | 07:58 PM
msgtord's Avatar
msgtord
The tpms has saved me from a blow out twice in the last 5 years. I'll keep mine hooked up.
Old Aug 12, 2015 | 08:34 PM
KH338's Avatar
KH338
I can only hope someone figures a way to delete it soon. The pressures that set off the warning light can be adjusted to a more reasonable pressure easily and quickly with the proper tool. If only traction control was so easy to modify life would be great.
Old Aug 12, 2015 | 08:45 PM
NYCruiser's Avatar
NYCruiser
The tires I run are rated for max pressure 65psi. I'd need to inflate them to over 70 to get the light off. It wouldn't be safe. My tires are E rated and perfectly reasonable for the loads of the truck. I'd love to just set the tpms alarm down to 55-60.
Old Aug 12, 2015 | 08:47 PM
KH338's Avatar
KH338
The max pressure for my tires is 50psi and my sensors are set at 40 psi with no lights on the dash.
Old Aug 12, 2015 | 08:50 PM
NYCruiser's Avatar
NYCruiser
I gotta stop at the dealer and see if they'll change it for me. That and get my auto-headlights I installed flashed. Just haven't had time.
Old Aug 12, 2015 | 09:36 PM
fishbones182
tpms delete
If your tires are e rated they are rated at 3195lbs at 65 psi. Most stock tires that are e rated require 70 to 80 psi to achieve that load rating. Best bet would be to chalk test your tires to determine the correct psi needed for your truck and load. You can adjust what psi the tpms sensors set the system off with a tuner or the dealer. However no dealer will disable it due to it being a federal law that it is required on the car or truck. No one will take that liability. Do you need it no. Do some people like it yes do I no. But I don't rely on it at all. I always do a full walk around of my truck before I drive it. Habit of driving big rigs I guess and driving on the farm here I just never know what might have made it way under my truck.
Old Aug 12, 2015 | 09:40 PM
NYCruiser's Avatar
NYCruiser
They're Nitto Trail Grapplers. They're marked on the sidewall "Load Range E", "Made in USA", and "Max Cold Inflation 65 PSI".
I run them at 60 PSI cold and they are wearing straight, but my stock TPMS light is always on.
If I inflate them to over 70 the light will go off, but I don't want to run them that way.
The stock tires I took off had max pressure 80 PSI, and the door jam says to inflate the fronts to 70 and rears to 80.
I know better than to over inflate my tires, but it becomes unsafe if someone else is running my truck and decides to air them up because of the light. I'm going to have to discuss that with the dealer and see what they can do.
Old Aug 12, 2015 | 09:45 PM
fishbones182
tpms delete
Just get a tuner ave change it yourself your pay the dealer to adjust it for you. On your tires you should be at 65 on the rear and 60 in the front. That is the only way around it add to bit over or under inflate your tires and cause poor tire wear. Been down this road many times.it's about 10 psi less then what's required according to the computer in the truck that is setting it off.
Old Aug 12, 2015 | 10:30 PM
NYCruiser's Avatar
NYCruiser
What tuner can do it?
