EBP Sensor or Sticking VGT?
Old Aug 9, 2015 | 03:21 PM
joejackF250's Avatar
joejackF250
I was at a stoplight today after pulling off a 100 + mile highway trip and I have it throttle and it was sluggish, I looked at my EBP reading on my scangauge and it was staying a constant 6.3 psi. I let off the throttle and the famous turbo bark sound happened. It did that for a few minutes and the EBP readings went back to normal and the turbo bark went away.
Please help.
Thank you!
Old Aug 9, 2015 | 03:50 PM
KDAVID1's Avatar
KDAVID1
Unplug the ebp and drive. If it is the sensor all shoukd return to normal.
Also keoe ebp, map, and baro should be close together.
Old Aug 9, 2015 | 03:54 PM
joejackF250
It returned to normal on its own minus the sluggishness.
Old Aug 9, 2015 | 04:02 PM
KDAVID1's Avatar
KDAVID1
Still
Check readings between the 3 koeo.
Also unplug the ebp. Only way to really tell if ebp or turbo that is quick.
Old Aug 9, 2015 | 08:58 PM
joejackF250
Originally Posted by KDAVID1
Still
Ok EBP was 15.0, BARO was 14.6, and MAP was 14.4
Old Aug 9, 2015 | 09:40 PM
KDAVID1's Avatar
KDAVID1
Ebp is probably good then however it probably needs pulled and cleaned along with the tube.. now you can look at other things. What did the vgt # look like when it was acting goofy?
Old Aug 9, 2015 | 10:18 PM
joejackF250
VGT looked to be in normal range. Usually seeing low to mid 60s at idle and 40s when cruising. Boost was normal too.
Old Aug 10, 2015 | 06:44 AM
KDAVID1's Avatar
KDAVID1
May have just been an engine brain far
I'd keep a watch on it. Reason I mentioned toe ebp was mine did the same thing a while back and was afraid I was going to have to do a turbo clean. My vgt and ebp was out of whack BUT only had a so called power loss one time that lasted about 5 miles. The loss was really just shift pattern. It would still haul just higher rpm before it would shift. I unplugged the ebp and all returned to normal until I could get a new ebp in. I actually got codes for low boost but my boost was normal. Forgot to ask what year as I think some early models use a different strategy for ebp.
Old Aug 10, 2015 | 07:50 AM
joejackF250
My shift pattern is a bit harsher than normal. I'm thinking about disconnecting my batteries and resetting my codes. And mine is a 2004 late model
Rod Jr.
Oct 4, 2014 08:43 AM
fixxxer-upper
May 30, 2013 12:21 AM
6LPSD
Feb 28, 2009 10:49 AM
misterc
Mar 8, 2008 02:05 PM
PAN
Nov 30, 2004 10:41 PM
