Over heating
Old Aug 9, 2015 | 01:38 PM
Silverfox0921's Avatar
Silverfox0921
Over heating
I have a 2000 Ex with 252,000 miles. I live in Springfield Mo
Where it is extremely hilly (Ozark Mountains). I tow a 6400 lb travel trailer. What I am having problems with is the Ex is running extremely hot when towing and climbing hills. Not in the red, but damn close. No problems what so ever when not towing. No problems when towing on level ground. I know the Ex is working hard, but I want to keep it running cooler. I have flushed the radiator literally 20 times and have done 2 chemical flushes. Is it time to just replace the radiator? If so what one do you guys recommend? How many passes does the stock radiator have? What about a bigger water pump? Any suggestions is always appreciated. I have the 5.4 motor, which I love so no bashing my little V8. It has all the power I need. I don't need to climb hills doing 90mph.
Old Aug 9, 2015 | 02:43 PM
harley4jcs's Avatar
harley4jcs
Apparently not if your overheating pulling your load
I would think you are describing that your fan clutch is out or surly on the way
Old Aug 9, 2015 | 02:54 PM
mecdac's Avatar
mecdac
What are your trans temperatures?
Old Aug 9, 2015 | 03:39 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
You need some digital gauges to accurately read temps. Scan gauge or torque app would show you how hot you are really running.
Old Aug 9, 2015 | 04:16 PM
R&T Babich's Avatar
R&T Babich
What size radiator did yours come with - 1 row, 2 row or 4 rows of cooling tubes? I was just looking thru radiators that are available for the 2000 Ex 5.4l. If yours is a 1 or 2 row you might be able to get the 6.8l 4 row in there. All the radiators listed were the same overall dimensions. Has anyone done that? The list doesn't state how many rows in every radiator, but the 6.8ls were 10 lbs heavier. I had an E-150 351W short bed van that I used for towing and put in a monster E-350 460 RV 4 row radiator that bolted right in. Never had a cooling problem after that. I suspect the V10s, 7.3s and 6.0s all came with the same 4 row radiator with maybe hose connection differences. Our 6.8l measures 2.25" thick at the cooling tubes.
Old Aug 10, 2015 | 01:34 PM
az_r2d1's Avatar
az_r2d1
Maybe a bit too obvious but; Did you try changing the thermostat? Use a motorcraft one.
Old Aug 12, 2015 | 02:00 PM
xplodn's Avatar
xplodn
I feel your pain brother. Just had head gaskets done on.mine due to overheating. I also went from the 1 3/4" think radiator to the 2 1/4" think radiator. Never had any issues with the other one and there seems to be no direct info on which one the V10 had front he factory. Seems they got whatever was available not like the v8 or diesel that had specific ones.
FiveOJester
2009 - 2014 F150
Jan 14, 2018 11:45 AM
rodderz
27
Feb 27, 2015 10:15 PM
kkeduda
All Things Towing
May 6, 2009 12:36 PM
Johnboy_BoomerSooner
1978 - 1996 Big Bronco
Jul 21, 2005 11:28 AM
millsman
1997 - 2003 F150
Nov 27, 2001 12:42 PM
