Roller cams for 393w help
I have a 82 Bronco with a 302 and I'm looking to put a 393w in it, i was planning on getting a pre 94 block and run a Comp Cams Xtreme 4x4 cam in it but today i picked up a standard bore F4TE block for $50 so i couldn't pass it up. Im looking for advice on a good off the shelf roller cam for my 393, I'm wanting to be somewhere around 400/400 in the power range and my Bronco will be a weekend toy. Any help would be appreciated, thanks
on
Good find, I don't understand why you were thinking of using an earlier block. As for cams what is your complete engine combo going to look like and will it be carbed or EFI? There are no stock heads that will deliver that hp level but if you get some that are capable then you have loads of cam options.
Thanks fellers and my engine will wear AFR heads and will not be fuel injected, I'm looking to build a fun weekend toy and I'm taking a break from building the Cobra for a couple years, I've been a member on and off this forum for over 10 years and appreciate any advice, i have absolutely zero experience with a roller block 351
Frozen_Joker
09-19-2012 10:59 PM
f-trucker88
01-02-2012 10:55 AM
78bigbronco
07-31-2006 08:33 AM
