4spd where a c6 was, same mount?
Old Aug 1, 2003 | 11:53 AM
cdd5599's Avatar
cdd5599
HI guys,
I am putting a np 435 4spd inplace of a c6. In my 1980 f-150 short bed stepside 4x4. does it use the same mount? YOU know the the long plate with two big bushings on each side. I have put a 4spd in a two wheel drive, but all i had to do was turn the cross member around and it was marked for 4spd.
thanks ,
Chuck
Old Aug 1, 2003 | 03:57 PM
bubbaf250's Avatar
bubbaf250
Depends on the engine. Some use the same trans mount for both manual and auto, some use different mounts.
On 1980 trucks, the parts catalog doesn't distinguish 4x2 from 4x4 for trans mounts, so they should be the same for both.
Old Aug 1, 2003 | 06:54 PM
bremen242's Avatar
bremen242
I've seen those type of mounts in a '82 4x4 bronco.. it was a 4spd.
there might be another set of holes you can use on the frame. my f-250 has two holes.
Old Aug 4, 2003 | 06:59 AM
cdd5599's Avatar
cdd5599
Ya it worked guys, bolted right .
thanks ,
CHuck
Old Aug 4, 2003 | 09:04 PM
steve83's Avatar
steve83
Mine originally had the NP-435, and it uses the style in the top L detail. Did you have to turn yours around or anything?
http://www.cybrrpartspro.com/Chilton.../85767008L.gif
Old Aug 5, 2003 | 07:11 AM
cdd5599's Avatar
cdd5599
Nope,
Didn't have to turn it around or anything. Transmission just sits on that plate. (same mount as yours)
thanks ,
chuck
1980 ford f-150 stepside 4x4 I-6 , np435, np208 3.25s
1980 ford f-150 longbed 4x4 351w, c6, borg, 3.50s
1965 ford f-100 stepside 2x4 351c, c6, 3.75s
