Matching oem vinyl?
Old Aug 8, 2015 | 09:20 AM
tommyduncan's Avatar
tommyduncan
Matching oem vinyl?
I recently bought an oem, never installed seat cover on ebay. It is gray vinyl with the Ford logo embossed. Unfortunately all that he had was the seat back cover. Now I need to have the seat bottom cover made to (hopefully) match.
Does anyone know what vinyl was used on that type of cover? If anyone has a picture that would be great also. What is left of the cover that is on the truck appears to be original but is completely different.
Old Aug 8, 2015 | 04:01 PM
Roger Carter's Avatar
Roger Carter
Check out SMS in Canby Oregon. They have a large stock of original materials.
Good luck.
Old Aug 9, 2015 | 10:52 AM
tommyduncan
Good luck.
Thank you. They have a few different vinyls for this vehicle. When I posted this I was hoping to get some material coming so I could get this done but the cover I bought isn't here yet. I have since found more issues wih the truck (I've only had it a few days) and now there is no rush. I will wait until it gets here and see if the shop can find a match.
SMS has come through for a lot of people on another forum I frequent (for my 55 Buick) but it isn't uncommon for them to take months. Hopefully this is a common material.
I found an OEM style cover on ebay and tracked down the manufacturer. They are using original materials so hopefully it is plentiful.
Old Aug 10, 2015 | 09:15 AM
theastronaut's Avatar
theastronaut
If it's the "paneled" material then SMS may have it, but it will likely be cut to short width-wise. We ran into that with the '66 we restored.
Old Aug 10, 2015 | 09:38 AM
tommyduncan
I saw that on your build thread (I read the whole thing last week) but I don't remember your solution since I didn't know I might have the same issue. That is one build thread I don't mind looking through again...
I also "borrowed" your air filter idea... I had the same air filter laying around that you used so I'm doing the same mod on the old oil bath housing. Normally I like to use a bigger filter than that out here in the dusty desert but it will be fine as long as I keep my eye on it.
Old Aug 11, 2015 | 08:16 AM
svolpone's Avatar
svolpone
you could always do a contrast color for the seat. that might look cool.
Old Aug 11, 2015 | 11:07 AM
tommyduncan
Good luck.
I have some samples on the way. The seat cover should be here today or tomorrow. Thanks for the replies.
Old Aug 12, 2015 | 06:41 AM
theastronaut
Dad had to make the side panels taller to make up for the SMS piece being narrower. If I remember correctly it was 4" too narrow compared to an original cover, so 2" on each side. The taller boxing doesn't look terrible, and actually helps the cover to have less wrinkles since the vinyl side material stretches around the top corners better than the top panel material.
Old Aug 13, 2015 | 02:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
According to your "About Me" profile, you have as 1966 F100.
No 1965 or 1966 F100/350 had a gray vinyl seat, you bought a 1961; 1962; 1963 or 1964 'lazy back' seat cover.
The BODY code is stamped on the 2nd line of the Warranty Plate, between the MODEL & TRANS codes. Post what it is.
Unless you have the Ford part number from the seat cover you bought, there is no way to ID what color the gray is.
Old Aug 13, 2015 | 07:45 PM
tommyduncan
481
Unless you have the Ford part number from the seat cover you bought, thee is no way to ID what color the gray is.
I think SMS figured it out. I won't know for sure until the samples get here.
The seat that Is already In It Is fawn basketweave.
Lazyback is a good name since it will leave the seat Innards exposed..
Old Aug 13, 2015 | 10:38 PM
tommyduncan
SMS sent me a picture of this material on a roll with the Ford logo and the same pattern already embossed. It isn't exactly cheap but since I got a decent deal on the 1/2 cover I already have I think I'm gonna do it.
I saw what I thought were stains on the back of the seat cover but they are random yellow letters. Now that it finally quit raining I'm going to check it out a little closer to see if there is a part#
EDIT
The only numbers on it are an "F" with the letters "A4" below it on the main, darker material and an "F" with the letters "C4" below it on the lighter border material.
The person that I bought this from claimed it is "unused, made in the Utica, Michigan factory".
Old Aug 13, 2015 | 11:24 PM
tommyduncan
Here is a pic of mine<a href="http://s197.photobucket.com/user/tommyd1963/media/Mobile%20Uploads/1970-01/20150812_135236_zpsnkkueqgj.jpg.html" target="_blank"><img src="http://i197.photobucket.com/albums/aa249/tommyd1963/Mobile%20Uploads/1970-01/20150812_135236_zpsnkkueqgj.jpg" border="0" alt=" photo 20150812_135236_zpsnkkueqgj.jpg"/></a>This is the picture SMS sent me
<a href="http://s197.photobucket.com/user/tommyd1963/media/Mobile%20Uploads/1970-01/P82A00311_zpsgljhpou3.jpg.html" target="_blank"><img src="http://i197.photobucket.com/albums/aa249/tommyd1963/Mobile%20Uploads/1970-01/P82A00311_zpsgljhpou3.jpg" border="0" alt=" photo P82A00311_zpsgljhpou3.jpg"/></a>
I think it's a match... the pic of mine was directly under a light so it effects the color.
Old Aug 13, 2015 | 11:47 PM
NumberDummy
1966 F100/750 ~ 481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
Matt1966
Mar 6, 2017 04:00 PM
NebraskaCowman
Jul 24, 2014 09:23 PM
bhocart
Mar 4, 2010 05:24 PM
TheWingnut
Mar 29, 2009 08:49 PM
nickmobile67
Appearance & Dress-Up
Oct 26, 2004 09:50 PM
