Aerostar Ford Aerostar
Steering wheel removal
Old Aug 1, 2003 | 10:12 AM
defly's Avatar
defly
I need to replace the turn signal switch on my 97 Aerostar, which involves removing the steering wheel. Can anyone outline the procedure for removing the airbag?
TIA
Old Aug 1, 2003 | 08:14 PM
Timothyap5vm's Avatar
Timothyap5vm
I would advise you to take it in to a dealer or someone who specializes in that sort of things. Under no circumstances should you try it yourself. You might do something wrong and cause it to deploy when you are driving. If you own a 86-91 Aerostar then you're fine since they don't come with airbags.
If you need to work arounds the airbag (repair dash or work under dash) then you should disconnect the battery and wait 5-10 minutes.
Timothyap5vm
1992 Ford Aerostar. ERROR kilometers, and still going!
Old Aug 1, 2003 | 09:34 PM
neilt's Avatar
neilt
Try checking the posts on 6-11-2003 about replacing the clockspring. It might give you the information you need. Ford says to remove the postive battery cable a minimum of 10 minutes before starting on the airbag.
Neil Townsley
1994 Aerostar
