everything comes through defroster
Old Aug 1, 2003 | 07:08 AM
ranlyn54's Avatar
ranlyn54
I have been reading all your reponses on this problem and have thoroughly run down all vacuum hoses and cannister connections and cannot find a thing wrong. How does this system work on a F250 7.3 diesel. Is there an electric pump that could be going bad ? Any help appreciated
Old Aug 1, 2003 | 06:01 PM
HomerWinzlow's Avatar
HomerWinzlow
Yes, the later model super duty 7.3 has an electric vacuum pump on the right hand fender well. It may have a blown fuse or is inoperative. You can test it with a regular 12v test light to see if it has power running to it, and you can feel and hear it run when the vehicle is running. If it is running and the doors still dont work, there is a plastic cap on the front of it about 2 inches round and 3 inches long. It has a tiny vent on the front of it that sometimes gets clogged up and prevents it from creating a vacuum. simply open that hole up with a pick or small drill bit. If it still gets no operation you probably have a vacuum leak. If you have a 4x4 a common source of a vacuum leak is the auto hub solenoid which is near in location to the vacuum pump itself on the right fender well. Check to ensure the vacuum lines all the way to the hubs are not broken. The valve itself is known to go bad and cause a constant vacuum leak. You can temp fix that by plugging the vaccum line to the 4x4 auto hub solenoid.
