'78 Ranger XLT rebuild with pics!
Old 08-31-2015, 08:00 PM
Heliguy's Avatar
Heliguy
Heliguy is offline
Well, I cleaned up the cab corner and it looks so much better. Also started to sand down the cab and to my surprise it isn't all that bad. thought.
  #32
Old 08-31-2015, 11:57 PM
burnthelight88's Avatar
burnthelight88
burnthelight88 is offline
Where'd you get the wheels and how much? I'm looking for the exact same ones
  #33
Old 09-01-2015, 05:30 PM
Heliguy's Avatar
Heliguy
Heliguy is offline
Thanks, we love them. We got them from Big "O" Tires which is the same as NTB I think. They are the American Racing Outlaw 2's. They were only like $80 each? I think you can get them at Discount Tire too.
  #34
Old 09-07-2015, 01:26 PM
Heliguy's Avatar
Heliguy
Heliguy is offline
Found a little more rust. Cut it out and patched it.
still have to do a little more sanding but no more rust.
  #35
Old 09-08-2015, 12:14 PM
Notmeofficer's Avatar
Notmeofficer
Notmeofficer is offline
I wish I had been here sooner.. great project
There is a mig wire called "easy-grind" is made for bodywork and is a softer steel.. it comes is .025 ,030...
I use the .025 in my little 140 Lincoln mig and it works great without overheating the sheet metal and grinds away smooth
Keep up the great work ...
  #36
Old 09-19-2015, 06:04 PM
Heliguy's Avatar
Heliguy
Heliguy is offline
[QUOTE=There is a mig wire called "easy-grind" is made for bodywork and is a softer steel.. it comes is .025 ,030...[/QUOTE]
Thanks! Ill look for some!
  #37
Old 09-19-2015, 06:09 PM
Heliguy's Avatar
Heliguy
Heliguy is offline
Well, I was out of town for a week so got back to work on the truck today. Weather was finally cool so I worked outside on the bed. The wheel wells had some real big rot holes so I got those fixed and will put in the new sheet metal tomorrow. Turned out quite well I think.
Cut out all the bad stuff with the plasma cutter. Patched the holes from the old roll bars too.
Replaces them one at a time.
  #38
Old 09-19-2015, 06:20 PM
F350Loui's Avatar
F350Loui
F350Loui is offline
Heliguy just a little hint when your putting in repair panels with square corners. You need to round off the corners, the heat will transfer around instead of out to the end.
  #39
Old 09-19-2015, 06:57 PM
Heliguy's Avatar
Heliguy
Heliguy is offline
Dang, I didnt know that! What kind of radius? Dime, quarter, coffee cup? Thanks!
  #40
Old 09-19-2015, 11:01 PM
F350Loui's Avatar
F350Loui
F350Loui is offline
On the wheel arches I'd do the size of coffee cups. Any square patch round the corners. On your inner box panel I would have made one long patch in stead of several small ones. Looks good though keep plugging away. Oh ya don't put in that inner fender panel throw it away.
  #41
Old 09-19-2015, 11:10 PM
Heliguy's Avatar
Heliguy
Heliguy is offline
Hmm... Well I may have screwed the pooch on this side then since its already cut.
So, don't put in the inner fenders? I bought a set cause I thought they had to go back in. Will it be rigid enough without them?
Thanks for the info. Im "learning as I go" with this one.
  #42
Old 09-20-2015, 07:26 AM
F350Loui's Avatar
F350Loui
F350Loui is offline
Heliguy I think I showed you these pic on another post but I'll show you again. Use the front liners in the rear. With some modifications they work great and good and secure. Then the box side won't get crap in between the to panels an rust out the wheel wells again.
Screw liner to the floor an inner side pinch weld. I use to make a track to go against the line ran run it along the pinch weld. I don't bother anymore.
  #43
Old 09-20-2015, 08:49 AM
Heliguy's Avatar
Heliguy
Heliguy is offline
Oh yea, you did. Ive seen so many cool ideas I forgot. Ill look into doing this. Thanks for the idea!
  #44
Old 09-20-2015, 09:37 AM
monkey-1's Avatar
monkey-1
monkey-1 is offline
Great progress. Thanks for sharing. Look forward to more pics as you continue the build.
  #45
Old 09-27-2015, 12:30 AM
Heliguy's Avatar
Heliguy
Heliguy is offline
Well, got the outer fender welded in and patched a rusted out piece at the front of the bed. Also bought a 40lb Sandblaster and wish I would have bought it months ago! Got the cheep one from Harbor Freight but it really works great. Going to do the other fender tomorrow.
Quick Reply: '78 Ranger XLT rebuild with pics!
