ignition trouble
Old Jul 31, 2003 | 09:19 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
ignition trouble
my 83 f100 has a really hard time starting. the ignition lock cylinder is really hard to turn to start. i have replaced the ignition switch and the key cylinder. in the winter the switch is so hard to turn you almost need a pair of pliers to start the truck. i unhooked the linkage that goes to the ignition switch and it works perfect. the ignition switch at the base of the column is too hard to move. used a napa replacement switch. anybody else have this problem? the switch slide doesnt want to move, especially to start. i'm thinkin this is a bad part to buy from napa.
Old Jul 31, 2003 | 09:27 PM
DieselMan04's Avatar
DieselMan04
ignition trouble
Napa isn't exactly the best place to buy parts...in my experience!Go online to ebay or to a ford dealer!Factory parts seem to be better unless your trying to customize your truck
Old Jul 31, 2003 | 09:33 PM
oldfordtrucksrule
ignition trouble
ya napa isnt ford oem quality, but ive never had any trouble with any of their stuff until now. and ive bought a lot of stuff from em. im probably gonna get a motorcraft one from the dealer and see if that one works better.
Old Sep 10, 2003 | 08:32 PM
tkcollin's Avatar
tkcollin
ignition trouble
Have you looked at the upper end of the rod and the gear that is up there? There is a gear just behind the lock cylinder that goes to the column lock actuator and ignition actuator rod. Mine broke entirely and I had to take the column apart to get to it.
