2004 f150 Cranks But Wont Start
Old 07-28-2015, 01:04 PM
jonathan mosher's Avatar
jonathan mosher
jonathan mosher is offline
I have a 2004 f150 Heritage (old body) 4.6L 160k on it. I drove it to work one day and 10 hours later when I went to start it, it cranks but wont start. The Ford garage said they thought it was hit by lightning because some of the modules weren't communicating with there computer and said they would have to start testing wires to find the problem. I stopped there because I didn't wont to rack up a bill more than the truck is worth.
So here's where I am now.
The truck turns over but wont start. It does however run "while" you are spraying starter fluid in the air intake. I've changed the fuel pump (and it does prime) and fuel filter. Changed cam sensor. Swapped some relays (never tried new ones just swapped around the ones that were the same).
They think the main computer is working because it is giving its 5 volts to each module they just don't know which modules are not working or if there are wires broke somewhere. Does anyone have any ideas or suggestions???
Old 07-29-2015, 10:53 AM
jonathan mosher
Anyone know???
Old 07-29-2015, 05:42 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Impossible to say, someone who knows what they're doing needs to be "hands-on".
Old 10-08-2018, 09:30 AM
javcarbe's Avatar
javcarbe
javcarbe is offline
Did you fix this problem, I'm in the same situation.
Old 10-09-2018, 04:54 AM
JWA's Avatar
JWA
JWA is offline
Received 1,410 Likes on 1,112 Posts
When the engine seems to run while spraying ether into the intake that tends to mean there's no fuel getting into the cylinders. My '03 E250's fuel pump failed so it had to be limped back into a garage with one guy squirting starting fluid into the intake housing, air filter removed.
Have you checked the actual fuel pressure at the rail while the engine is cranking? That might tell you a lot.
BTW I'd think if lightening struck your truck you'd have almost no electrical power or function at all. Do the lights, radio, wipers, blower motor etc etc work still?
HTH
Old 04-05-2023, 02:16 PM
Mustang ( Jeff )'s Avatar
Mustang ( Jeff )
Mustang ( Jeff ) is offline
4th Gear
No start problem
HEy there, I just wanna let you know that something similar happened to me, it actually about blew me away when I found the problem and then figured out what caused it. It would definitely make good sense if you have big trees around where you work. Anyways to the point, yes, it was a squirrel that chewed up some wires causing my vehicle not to start. The main point is to be sure to check all of your wiring in the engine compartment and under the vehicle? Good luck!
hdscott2018
2004 - 2008 F150
04-06-2023 09:23 AM
DeanFrank
2009 - 2014 F150
07-26-2017 07:23 PM
gabbie
06-21-2010 07:09 PM
Bassin56
2004 - 2008 F150
04-25-2010 09:30 AM
Quick Reply: 2004 f150 Cranks But Wont Start
