Fuel problems
Old Jul 26, 2015 | 09:51 PM
allen23923's Avatar
allen23923
Fuel problems
Here it is in a nut shell ethanol fuel its gumming it up ....If U have Duel Tanks no codes unplug in line pump put jumper in test port aka ground to pumps and listen to hear if pumps in tanks running also the valve that turns front to back is a weak link so it will burn pumps in tanks and also fill one to other..just to see if u have power to them red wire front tank brown white stripe back tank ...if no power check fuse then relay then kill switch at firewall
Lee bias
Dec 29, 2016 10:40 PM
Aridecommando
Dec 10, 2015 08:56 AM
hawk205
Sep 19, 2004 09:34 PM
craigebear
May 16, 2004 10:18 PM
woodysfj40
May 21, 2003 01:22 PM
