some questions
Old Jul 26, 2015 | 03:39 PM
RadioControlGuy85's Avatar
RadioControlGuy85
some questions
hey guys, we just got a 92 f150 custom 5.0L
it was my grandfathers,he past away last month.he was great guy.
here are the problems we are having.
my dad went to go get it.and he said it was hard to get it to fire up.he got it back to the house and we poped the hood.and found about 3-5 connectors unhooked and one of those was the IAC so i reconnected and fired it up.she went right up to very high idle.so im guessing its the IAC,but my dad said he replace that not to long ago.
it has the dual tank setup.my grandfather said awhile back before he pasted that the front tank didnt work.but when my dad got it back to the house we checked it and the front tank fuel pump kicks on.when we start the truck you can hear it running the fuel tank is empty. it would do that if its empty right?
Old Jul 26, 2015 | 04:22 PM
fordboy97's Avatar
fordboy97
some questions
Sounds like you might have a high tps voltage at idle, should be .5-1 volts if I recall correctly. But as they always say, pull the codes
Old Jul 26, 2015 | 06:07 PM
RadioControlGuy85
how do i pull the codes?
Old Jul 26, 2015 | 09:15 PM
88XLTLariat's Avatar
88XLTLariat
https://www.ford-trucks.com/forums/1...er-to-use.html. Read this thread.
Old Jul 27, 2015 | 07:55 AM
Zorfox's Avatar
Zorfox
You do need to pull the codes. I would also determine why the connectors are disconnected and hook them back up. You don't need a code reader for your truck. You can read the codes by using a jumper and counting the check engine light flashes. I have the same truck and have done it many times. Here is a post that explains how to do that...
How-To: retrieve trouble codes- OBDI - Ford F150 Forum - Community of Ford Truck Fans
Old Jul 27, 2015 | 01:50 PM
RadioControlGuy85
ok thank you.ill let you know what comes up
Old Jul 30, 2015 | 09:39 PM
RadioControlGuy85
while the engine is running, i unpluged the IAC nothing changes.
plus its hard to start you have to pump the gas for it to start
here is a pic
Old Jul 31, 2015 | 04:22 PM
RadioControlGuy85
well got the code reader today and got these codes
111 with a o 10 and a 111 with a c
said in the book there both system pass
so what dose this mean? vacuum leak?
Old Jul 31, 2015 | 04:33 PM
rla2005's Avatar
rla2005
Take a look at the throttle stop screw. It's not an idle speed adjustment. If someone jacked with it then the base idle can be affected.
If the screw looks to be unmolested then you have a vacuum leak.
Old Jul 31, 2015 | 04:41 PM
RadioControlGuy85
when the truck is cold,and you start it how long should it take for the idle to come down to normal?
i just started it and it took idk 30 or so seconds for it to come down.
Old Jul 31, 2015 | 05:12 PM
rla2005's Avatar
rla2005
Looks about right to me with the last three OBS trucks I have owned.
Old Jul 31, 2015 | 05:17 PM
RadioControlGuy85
why would it come and go?
and why is it hard to start.
Old Aug 1, 2015 | 03:29 PM
RadioControlGuy85
have resetting the computer i drove around for a bit got back to the house and put the code reader on and got these two coded
code 542 is a Fuel Pump Secondary Circuit Failure
code 121 is Closed throttle voltage higher or lower than expected.
the tps has been replace twice that i know of.
so what the heck todo?
Old Aug 1, 2015 | 10:18 PM
fordboy97's Avatar
fordboy97
some questions
For the code 121 I'd check the voltage of the tps, make sure its within range. I elongated my tps screw holes with a drill bit to adjust it. This isn't required its just what I did.
Old Aug 1, 2015 | 10:34 PM
RadioControlGuy85
ok ill do this when i get my meter in.
Fordf1504life
Nov 1, 2020 05:50 PM
The White Falcon
Jan 5, 2013 11:58 AM
torquemeister
Mar 17, 2006 06:35 PM
repman17
May 14, 2005 09:23 AM
