Turn signal problem
Old Jul 31, 2003 | 04:32 PM
labrouse's Avatar
labrouse
Turn signal problem
1968 Ford f100: i need some help on where to begin with finding out why my turn signals don't work but my four ways will. If any one can get me going in the right direction it would be greatly helpful.
Old Jul 31, 2003 | 05:21 PM
MuchToMyDelight's Avatar
MuchToMyDelight
Turn signal problem
i assume that "four ways" mean emergancy flashers. There should a seperate fuse for the turn/stop lights, and for the emergancy flashers. There are also 2 flasher modules somewhere in the maze of wires under the dash, one in a clip above the brake pedal, and the other on the left side somewhere (mine got tucked away, couldn't find it) but I know its there. Start with the fuse, then try a new flasher ($2-$3)
Old Aug 1, 2003 | 09:54 AM
MuchToMyDelight
Turn signal problem
You figured it out yet?? If not, I don't know what else it could be, other than your blinker switch in the steering column, or the wiring to it.
Old Aug 1, 2003 | 10:49 AM
labrouse's Avatar
labrouse
Turn signal problem
I went out and looked at it and it looks like the fuse box has been replaced. I don't see a slot for the emergency flasher fuse. If this is the case how do i find the wiring that goes to the flashers
Old Aug 1, 2003 | 12:55 PM
MuchToMyDelight
Turn signal problem
I emailed you. read it and email me back.
