Sponsored by: Real Truck
5r110w Shift issues
Old Jul 22, 2015 | 10:56 PM
126mediczb's Avatar
126mediczb
5r110w Shift issues
First off thanks for any responses, second if I posted this in the wrong category I apologize....
Background 2006 F350 5.4L 3V, 4WD, K&N CAI, Superchips tuner, 3.73 gears, Jett MAF, 215,000mi.
My issue is I have a shift problem from 3-5. This doesn't happen when I'm granny driving, only under a hard acceleration. The problem is the tranny doesn't seem like it wants to upshift. RPM goes up but the truck doesn't accelerate unless I let off the gas. I have changed the fluid and filters every 20k since I got the truck (150k). This problem came up after I changed my fluid and filter a couple days ago. This time I changed to Mercon LV because I couldn't find Mercon SP (which is okay according to ford TSB). I used Valvoline max life ATF which said it was Mercon LV compliant. So is this the fluid type (multi ATF, Mercon LV compliant) or a bad solenoid from my understanding it would be the direct drive solenoid? Or am I SOL? Thanks in advance!!
Old Jul 23, 2015 | 04:19 AM
Mcrafty1's Avatar
Mcrafty1
Subscribed...Wondering about the Valvoline Max Life also....
Old Jul 23, 2015 | 04:58 AM
redrivergorge's Avatar
redrivergorge
I don't know if the fluid did it but I would only use motorcraft atf. I've heard bad things about any other brand that says its up to spec when its really not. I would of held out for Motorcraft SP thats all my 5r110 gets.
Could the wring harness have gotten tweaked or something?
Im50fast
Sep 11, 2016 10:43 AM
Lattitude Adjuster
Oct 10, 2014 07:44 PM
rjtlawncare
Oct 17, 2012 12:37 PM
jsnap
May 14, 2007 08:01 PM
John with beastly 302
Oil & Lubrication
Nov 3, 2003 04:05 PM
