camber bushings
Old Jul 31, 2003 | 03:47 PM
Fordnite302's Avatar
Fordnite302
camber bushings
anyone have some tips on installing camber bushings, and mostly removing the old ones?
Old Jul 31, 2003 | 08:17 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
camber bushings
there is special tools for removing them
Old Aug 1, 2003 | 08:19 PM
rclarke's Avatar
rclarke
camber bushings
I used a pitman arm puller for many years of front end work. If the bushings are aftermarket aluminum or 2 piece the only way I know is a big hammer and a long heavy chisel.
Old Aug 3, 2003 | 04:17 PM
steve83's Avatar
steve83
camber bushings
My alignment shop couldn't get mine out (of the '96 axle I'm using), so I soaked them in Liquid Wrench for a few days and used a LARGE flathead screwdriver to vibrate them out. I backed off the nut so there was ~1/16" gap, then tapped the little vanes on the side toward the slot in the bushing, so it was sort of "closing". Eventually, I could see it move up to the nut, and then it came out easily.
Look at these 2 pics.
http://www.superford.org/registry/ve...641&original=1
http://www.superford.org/registry/ve...640&original=1
SAF
Ford Truck Parts for Sale
Feb 11, 2013 08:07 PM
manyolcars
Dec 1, 2012 09:55 AM
Chaos 95
Aug 3, 2011 01:34 PM
MER
Offroad & 4x4
Feb 9, 2008 07:27 PM
72f100
Sep 13, 2002 07:15 PM
