6.0
Old Jul 22, 2015 | 09:35 AM
john c Wilson's Avatar
john c Wilson
have 2007 6.0, rouph idle starts, rouph and no power till engine reachs running tempeture,runs great after that.if engine is off for half hour,and restarted ,runs rouph again till engine temp is back again. any ideas ...wilson
Old Jul 22, 2015 | 09:38 AM
npccpartsman's Avatar
npccpartsman
Injector stiction or FICM. You're going to need some kind of monitoring to get a good idea of what's wrong.
Are you using Motorcraft oil filter and what kind of oil are you running?
Old Jul 22, 2015 | 09:40 AM
mhoefer's Avatar
mhoefer
You need DashBoss or SG2. Start with FICM voltages.
Old Jul 22, 2015 | 06:51 PM
04badford's Avatar
04badford
your FICM needs to stay at 48.5 / 49. V , If I were you, check the Charging system = Alternator Volts do a bench test , Both Battery's Load test each separate, If you seeing FICM below 45v it's time for Ed to getcha going , But don't wait your Injectors will thank you OH and if your still running the 110 amp Alt might be time to upgrade to at least a 140 amp or Higher
reamer
Mar 11, 2015 07:42 PM
AKPOWERSTROKE
Aug 15, 2012 11:16 PM
Millenium Edition
Apr 11, 2012 01:47 PM
Robby Nash
Feb 25, 2012 02:38 PM
sneak
Feb 11, 2005 04:23 PM
