help with flywheel removal
Old Jul 22, 2015 | 08:17 AM
umbagog1's Avatar
umbagog1
I have a 53 f100 that I am in the process of replacing the clutch. Hav no issues removing tranny, pressure plate but trying to drop flywheel to be resurfaced and cant get it to drop out of the bell housing. Ive removed the starter but ring gear teeth appear to hang up on iside bottom of bellhousing and wont drop ot. Am I missing something?
Old Jul 22, 2015 | 08:45 AM
Ibuildmyown's Avatar
Ibuildmyown
I would say pull the bell housing off.
Old Jul 22, 2015 | 09:13 AM
umbagog1's Avatar
umbagog1
problem is the engine is in the truck and in 53 the rear motor mounts are part of the bellhousing
Old Jul 22, 2015 | 09:20 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Support the engine (flat V8?) by the oil pan, with a jack and a wood block, at the front and rear. Needs to be solidly supported to be yanking on the flywheel bolts!
Welcome to the forum!
Old Jul 22, 2015 | 09:27 AM
umbagog1's Avatar
umbagog1
Yep flat v8, was hoping not to have to do that , but might be my best shot, seems silly that there wouldn't be enough clearance through the bottom opening to drop the flywheel.
Old Jul 22, 2015 | 10:02 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Have you tried cocking it rather than dropping it straight down?
The front support may be enough if you have a big wide floor jack at the rear.
Old Jul 22, 2015 | 11:35 PM
bigwin56f100's Avatar
bigwin56f100
I thought it would fit out through the bottom I know the y block will and the 223will too it has to be just right. I recommend you try again
Brian460
18
Oct 15, 2023 09:00 PM
F-1
Jan 13, 2017 07:48 PM
oneminizut
Washington Chapter
25
Jun 14, 2007 12:14 AM
mh822
Feb 19, 2006 04:56 PM
stanky
Jun 21, 2004 03:48 PM
