Kingpins
Old Jul 20, 2015 | 05:11 AM
Johno.h's Avatar
Johno.h
Kingpins
Replacing kingpins with a rebuild kit, is it a job to take to the mechanic or can I tackle it in my garage? What makes this job difficult?
Old Jul 20, 2015 | 06:20 PM
billabongboy73's Avatar
billabongboy73
From what I understand as long as you can get the pins and bushings out then you may not need to take it to a shop until you need to get the bushings in. Once they are in they may need to be reamed because the bushing may compress while they are being putting them in. If they don't get reamed then the pin itself may not go in right or have the play that it should.
Of course if you have access to a shop press and a reamer then you could do this yourself. Check these sites out. They are for older trucks but I figure kingpins are kingpins.
TECH: Kingpin & bushing replacement- Ford spindles. | The H.A.M.B.
Kingpin Replacement for your old truck
kdaug5
17
Mar 5, 2016 06:09 PM
jd_sylvia
Feb 18, 2016 09:22 AM
Marty69F250
Jun 12, 2014 10:00 PM
towtruck1
Aug 2, 2006 03:37 PM
pootscratch
13
May 12, 2004 05:36 AM
