Basically I would like it if the rear of SUV reacted to bumps the same way the front does. No bouncing.
As Willie S would say "therein lies the rub."
Any 3/4 ton vehicle is going to react to bumps differently when loaded or unladen.
The front always has the powerplant in front and will react accordingly, the rear based on applied weights will react differently.
Well OK then, that is the job of the shocks, to damped (and stop) the bouncing from going over bumps. Air bags could stop the bouncing IF you aired them up so high that the suspension didn't deflect at contact with the bump, but that might not be what you are looking for.
The EX was given some fairly crappy springs (front and rear) from the factory, upgrading to the springs from a SD truck will deliver better load handling and ride. Better load handling by having higher rated capacities and a better ride by having more travel up front (to stop the bottoming out) and the SD rears are a dual rate design that rides better, smoother. No matter what springs you end up with (even with an air ride/air spring setup) you will need good shocks to control the cyclic motion following a bounce.
I have V code new OEM springs up front and C code DRW springs in rear.
This is just my opinion but it seems truck springs are designed to work with and empty/light bed and once loaded different rates kick in. Problem is the excursion is always heavy in rear. Heavier when towing but still heavier than a empty bed.
My 2012 E350 van with factory springs does not bounce over bumps. Granted if you are sitting in the back it will push you up off the seat. Why does my excursion with higher rated springs bounce? Spring rate?
Will any E350 rear springs fit an excursion? I think the van springs would be a better option as they are designed different than truck springs.
From what was said shocks control cyclic rate, mine cannot. Fairly new blistin 4600 series. They do fine up front but not inrear. Hience the reason for this post. So I need better shock? What shock would work?
I am starting to think that my 4600 series shocks are wrong for my setup. Since the new springs raised the rear a couple inches they may be over extended. I will spring for a couple 5100's and see what happens.
I think you'll like them a lot more than what you have. My front end bobs more than the rear does, even when unladen. Mind you it's not ridiculous bob, just a little more than the rear.
5100 shocks in rear, and HDs in front are just the ticket. Not sure why, could be rear HDs were just a tad short or valved different but rear of X is much more stiff and does not bounce like it did before with the HDs back there.
