1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
BC3Z-15200-BA XLT Fog Lights
Old 07-26-2015, 09:11 PM
TosaFords's Avatar
TosaFords
TosaFords is offline
Originally Posted by MB49Caddy
That is what they told me at the dealer where I purchased my truck. So not sure what to do here.
My best course of action may be to try to order the XLT kit, but not sure the dealer will install it if they don't feel like they can cover it under warranty with my build date which I will confirm but I believe is after 8/14.
If you have the power windows then the XLT kit will work.
If you don't mind turning a couple wrenches you should be able to isntall the kit yourself in less than an hour.
All you have to do is remove the black covers. Then install the brackets and fog lights.
There's a capped plug on the bottom of the frame below the radiator that you will plug the included harness into. Plug in the harness and attach it to the holes in the bumper using the push pin clips mounted to the harness.
Then go inside the truck and pop the panel with the headlight switch off. Unplug the old switch and remove it from the panel. Install the new switch and plug it in. Put the panel back.
Turn the key and enjoy your new foglights.
Fog lights should work by just plugging them in. The Auto headlamps will likely require a BCM reflash from the dealer.
I had this same problem when I bought my SD almost 3 years ago. I bought the XL kit with the new BCM and wound up throwing it away.
Old 07-27-2015, 05:31 PM
MB49Caddy's Avatar
MB49Caddy
MB49Caddy is offline
Thanks TosaFords. looks like that might be the way to go. Not a wrench but with help from a buddy of mine we can probably do it during a weekend day.
Thanks.
MB
Old 07-27-2015, 07:13 PM
NYCruiser's Avatar
NYCruiser
NYCruiser is offline
The wrenching part is really easy. You'll do it in much less than a day. Took me about an hour or so and I'd never done it before. The instructions were pretty good.
Old 08-05-2015, 09:58 PM
gustrider4's Avatar
gustrider4
gustrider4 is offline
Just to update, kit was easy to install. And the "auto lamp" works, kinda.... it works in the sense when you turn the igniton on or off. lights go out when key is off. However, they will always be on day or night with key on which I find no problem with. I just have "daytime running lights"
rwilimo
26
02-10-2024 04:46 PM
SXIPro
08-04-2016 09:55 PM
BillME
05-06-2015 10:06 PM
troverman
05-01-2013 10:28 AM
Lt CHEG
13
11-25-2010 07:07 PM
Quick Reply: BC3Z-15200-BA XLT Fog Lights
