1956 FORD COE C600 BUILD
Hi Tom:
As you know I am using a 2003 E350 chassis for ease of mounting, due to my lack of extraordinary skills like many of the helpful members on this site.
The most important aesthetic issue, in my opinion, is centering the wheel in the fender well, and filling the space with a large enough tire. I am sure some of our knowledgeable members will come up with a solution for me and you.
Regards, Mark.
Regards, Mark.
well FTE....
I found a donor chassis.
1998 E350 with a 7.3 powerstroke turbo diesel.
only issue is the guy thinks it has a blown transmission.
So....I went on line looking for a replacement transmission.
I find their are 3 possible transmissions.
can anyone explain what the difference is???
3 different 4r1000's
A.T., 4R100, 8-445 (7.3L, diesel), ID F8UP-DA
A.T., 4R100, 8-445 (7.3L, diesel), ID F8UP-EA
A.T., 4R100, 8-445 (7.3L, diesel), ID F8UP-TA
and one e40d
A.T., E4OD, 8-445 (7.3L, diesel)
why are their three different choices for the 4r100?
will any of the three work in the place of the other?
will a e40d work in the place of a 4r100?
and one e40d
Any photos or build info to help me along??
well gang..... the donor got picked up today..
and rolled into my buddies garage for tear down.
we removed the box.....
And then the bare chassis was rolled out....
and the box was placed in its new home.....
Next is to strip the cab....
but that's another days project.... Tomorrow is a car show day!
Yesterday was a good day. I spent the afternoon working on the 1998 E350 7.3l Diesel donor.
Here they are side by side back at the homestead....
I started with the fuel level sender. You see since in bought the truck I have had a full tank of fuel. I figured I couldn't be that lucky, so I pulled the sender/pickup from the tank in order to check the condition of the sender.
after a visual inspection and testing I have determined that the sender has failed.
yeah.... I broke a stud..... damn rust.
I have searched around the web only to find the sender for this truck is in the $300.00 -$400.00 range...
Once I get the cab mounted and rewired I will worry about a sender.
either I will break down and purchase a new one, maybe I will find a truck sender and see if they are the same for the aft tank units.... maybe I will get lucky and find another cutaway in a salvage yard with a good sender....
and after a solid afternoons work.... the cabin is stripped.
I was left with a nice pile of steel from the dash support assy, and all the plastic junk that was attached to it.
and of course the main reason for all that work.
the dash side wiring harness.
next weekend I am not working on the Crew cab project I will strip the nose off the E350 and start separating the cab from the chassis.
Fuel pump for your tank
Is this what you are looking for? $69.70 @ Rock Auto
.More Information for RETECH RE0841S
Regards, Mark.
Regards, Mark.
Regards, Mark.
Regards, Mark.
close.... this would be the correct one.
And the one you listed is for a 5.4 gas engine truck.
There is no fuel pump on mine and the sender/floate arm is much longer
MotorcraftPS146 $278.79
#29
well gang it was time to finish stripping down e350 and make room for the c600 cab.
I started by separating all the remaining goods from the cab.
Heater hose
2 computers
electrical connections to dash
brake booster
etc
etc
And then broke out the trusty come-a-long and pulled the cab to the back of the chassis.
which left me with a nice wide open chassis.
And here is the 56 cab resting in its temporary position on the 1998 e350 chassis.
And the nose now slide on the e350 vans radiator support.
As you can see the coe cab needs to be move much further forward.
Which will also require some trimming of the floor/radiator support for engine clearance.
and the coe nose needs to be moved in a few inches.
Heater hose
2 computers
brake booster
etc
etc
#30
