1. NO, TBS's, Tornados, and Gas Additives do NOT add any significant horse power, and actually have the potential to do harm.
2. K&N products do NOT add "20-25" horsepower. They do, however, help your intake breathe, which MAY provide a slight increase in throttle response.
3. There is NO "kingofthehillendalldoallbestoneinthewholewideworl d" lift kit. Find one that fits your needs. There are a few that people recommend against. Search.
4. Yes you can fit 35's on a 4" lift. They will rub without modification of some sort.
5. Bigger Tires? Regear. Yes, it's been done with stock gears. Do yourself a favor, regear.
6. More horsepower? Intake and Exhaust, first and foremost.
7. Pings? Try higher octance gas. Good bit of advice; octane requirements rise in direct correlation to outside temperature. Over 90 degrees? Use higher octane. (Not always, obviously, just a good rule of thumb)
8. Which headers/mufflers/exhaust? If you're looking mainly for tone/sound quality, Flowmasters rock, but no two trucks will sound the same, so pick one and hope for the best. Performance-wise, search... it's been done.
9. Tires? Goodyear MTR's or BFG MT's. (Not the ONLY choices, but definitely a place to start)
10. Water is wet, the sky is blue, rear mains leak. Unless you're dumping massive amounts of crude on your driveway, leave it. Just check the oil more often.
11. Door locks? They break. Check for voltage to the switch, and to the actuator. It will more than likely be fine. Replace the actuator. ($20 aftermarket)
12. Suspension Lift > Body Lift
13. Search, search, search, search, search. IF you don't find anything, try fewer words and search again.
Originally posted by greystreak92 Rear exiting the exhaust (duals or otherwise) is a BAD idea.
I can second that. Mine exit the rear and I can't even so much as crack the rear window. Kinda sucks. But, on the bright side, it looks real cool from the back.
If someone told you your top would leak if you ever took it off, punch them in the nose and take the top off anyway. Because they are blithering idiots and stupidity should be painful!
