Adding oil pressure gauge
Old Jul 31, 2003 | 08:29 AM
dfawvor's Avatar
dfawvor
88 F-150 302 - have owned this truck for 3 months and my oil pressure originally stayed at the "N" on normal on my useless oil guage. It is now consistently halfway between "nada" and the "N". Want to install a mechanical oil gauge to get a better reading, but don't know where the sensor attaches to the engine. Can you tell me?
Old Jul 31, 2003 | 12:02 PM
c_rossman's Avatar
c_rossman
I removed the stock oil sensor, took the wire from that and grounded it to the frame so the oil light wasnt on all the time. I bought an electric gauge that reads PSI for 30 bucks. The mechanical ones are a bit more accurate but a friend of mines oil tube broke and had hot oil shooting all over his cab. what a mess!
Old Jul 31, 2003 | 12:04 PM
c_rossman's Avatar
c_rossman
IF you look by your oil filter there should be a fitting that has one wire that screws into your block, that is the pressure switch.
