Attention Gearheads:
Old Jul 31, 2003 | 03:26 AM
Ranger1500's Avatar
Ranger1500
Question Attention Gearheads:
I'm sure this is elementary to most of you but it's chinese to me. When an engine is a 360 or a 409 or a 302 or whatever, what does that mean?
Also, if Ford has, for example, a 360 engine, might they have 2 or 3 different versions or configurations or whatever of that 360?
Once they have a 360, for example, do they keep the blueprints and go on to make other sizes until they have a stable of all different sizes of engines and then reuse the designs in different cars in different years as they see fit? How do they decide which to use?
I hope this doesn't bring down the level of the discussion but it is important to me and it might give you all a chance to show off your knowledge.
Old Jul 31, 2003 | 07:39 AM
pfogle's Avatar
pfogle
The number is the Cubic Inch Displacement.
Yes there are many flavors of all Ford v8s.
-- Car
-- Truck
-- industrial
-- Marine
Yes the 390 is a 360 with a diff stroke and bore. Same block tho.
Old Jul 31, 2003 | 07:43 AM
Ka0TTiC's Avatar
Ka0TTiC
Dunno much about the other stuff, but I can answer your first question.. A 302 (and all the others) is called that because that is the displacement (302 cubic inches).
Aaron
Old Jul 31, 2003 | 01:35 PM
E150X's Avatar
E150X
FORD 302 is 302 cubic inch Windsor block engine from about 1968 untill around 82? Then after called the 5.0 because of design changes.
Old Jul 31, 2003 | 01:43 PM
90f150moneypit's Avatar
90f150moneypit
All manufacturers changed to the metric method of sizing.
examples;
Ford
5.0 L = 5000 CC
Chev.
5.7 L = 5700 CC
Old Jul 31, 2003 | 02:07 PM
E150X's Avatar
E150X
Yes but the 5.0l doesn't have the threaded hole for clutch linkage, different harmonic balancer/flywheel.... Not a direct interchange.
