'56 F600 Steering Box in a '56 F100
Just finished installing an F600 steering box in my '56 F100. This is an easy improvement (if you can find one) and the box though about 25% physically larger than the stock box, will fit even with the full size FL-1A oil filter on a Y block.
The mounting flange fits in the frame channel, and two holes need to be drilled (I did one in the frame and the other though the flange) but it's quite easy to do since one of the holes lines up just right after the box is in and the stock column is in position. The stock F100 pitman arm is used too.
The steering is much easier, (no not like power steering), and it looks essentially stock. If you are tired of nursing those weak F-100 steering boxes from this era, and don't want to go with power steering, I highly recommend this conversion. The truck really steers well now, and the old box was still pretty tight, so maybe it's the size of the parts or something.
Doing this finally gave me a good opportunity to fix the worn out turn signal switch and get the horn working properly too!
When I do these I swap over the column tube and shift linkage from the f100 box to the f600 box. I'm fairly sure Steve did it this way since I only sold him the box with the steering shaft.
What type of vehicle did your f600 steering box come out of? We have a 1956 ford f100 that needs a new steering box. We have found a donner vehicle that is down the street and wondering what type of vehicle you got yours out of. We are stuck and need some help.
Thank you for your time
Steve
07-07-2014 08:27 AM
eberhama
08-31-2012 03:58 PM
JBravo
08-10-2012 11:30 AM
rcflyr
07-21-2001 12:12 PM
