I wish I knew of a supplier for some polyurethane bushings. The last two sets I replaced with rubber were Chinese junk from LMC and MACs and lasted no time.
I just purchased 4 upper and lower transfer case mount bushings (insulators) from Energy Suspension and they look perfectly cut - plus they are poly which means they wont blow out. All 4 with washers for 29.99 plus shipping. Thats WAY less then the OEM rubber ones - if you can find the lowers in OEM rubber...
