f100 leaf spring question
Old Jul 11, 2015 | 01:07 PM
Four.on.the.floor's Avatar
Four.on.the.floor
so the back of my f100 sits and 1 to 2 " lower than the front. I really dont like the look when i can tell but its not something that needs to be done today.
a while back I was reading and searching on the web and I remember somewhere I read that I might be able to pull leaf springs off a f250 or 350 and put them on my f100 for about a 1-2" lift depending on how worn they were.
I tried researching before I came here but came up empty handed. thanks for the help.
Old Jul 11, 2015 | 04:09 PM
0toF100's Avatar
0toF100
If the ride is still okay you could you could probably find 2" suspension lift blocks instead of sourcing out all new leafs.
Old Jul 11, 2015 | 09:12 PM
kh0432's Avatar
kh0432
I had the same problem with my 98 Explorer. Tried coil over shocks but realized it was only a patch. Replaced the leaf springs and now it's back to normal. Do it right the first time and replace the springs. Not too expensive and pretty easy.
Old Jul 11, 2015 | 10:36 PM
82F100SWB's Avatar
82F100SWB
Your truck being a 2wd has 2.5" springs, limiting your choice of springs to F100's and 2wd F150's.
A good set of replacement springs is not that expensive for your truck, and if you are staying stock rideheight probably your best choice.
Old Jul 11, 2015 | 11:36 PM
Four.on.the.floor
okay thanks guys
greenmachine55
May 18, 2016 12:01 PM
KansasJoe
Oct 15, 2012 11:15 PM
Will9879
Nov 25, 2007 08:32 PM
OLD RED 82
Jan 15, 2005 06:27 AM
390fe
May 31, 2000 12:00 AM
