gear ratios
Old Jul 30, 2003 | 10:47 PM
stonework's Avatar
stonework
gear ratios
hi folks. i have a 97 f350 psd srw. don't tow much with it. work truck as well as personal vehicle. wondering if i have the right gear ratio for my needs... it does about 55 at 1800 rpm in overdrive. i'd like to see it go faster at this engine speed. any thoughts? thanks
Old Jul 31, 2003 | 12:10 AM
Ggg6's Avatar
Ggg6
gear ratios
There were only 2 axle ratios offered in 97, 3.70,4.11. From what I have found out there is maybe a max 2mpg dif in the city between the two. Do you have the stock size tires? This will make a difference on rpm at a given speed. I don't drive 55 much but I have 265/85-16 tires (stock size) and I run about 2200 rpm @ 70 mph.
Old Jul 31, 2003 | 07:33 AM
SHartman's Avatar
SHartman
gear ratios
Not true, my 97 has a 3.55 ratio.
Old Jul 31, 2003 | 09:32 AM
Ggg6's Avatar
Ggg6
gear ratios
You learn something new everyday
Old Jul 31, 2003 | 01:19 PM
johnsdiesel's Avatar
johnsdiesel
gear ratios
Correct, the only 2 ratios offered with the diesel were 3.55 and 4.10. Currently they only offer 3.73 and 4.10 (dually only).
Old Jul 31, 2003 | 04:26 PM
stonework's Avatar
stonework
gear ratios
thanks for the info. my tire size is 255/85-16. i have to run 2200 ish to do 70. be nice to do 70 down around 1800. seems like a good engine speed for the highway. is there anything i can do?
Old Jul 31, 2003 | 07:41 PM
Quadzilla's Avatar
Quadzilla
gear ratios
It sounds like you've got 4.10's. To drop your rpms significantly, you'd need to get taller tires. Much taller tires. I've got 35's on my truck, which also has 4.10's, and I'm turning 2000rpms @ 69mph. To get down to 1800rpms, you'd have to go to 38's, which probably wouldn't be practical. All of your options are a litlle pricey. You could get an overdrive/underdrive unit, install taller gears in the differential(s), or go to taller tires, with a lift kit, etc. You'd likely never save enough money on fuel to recoup the expense of the mods.
Just try to be content in the fact that you're in a good spot in the powerband for torque, and you can tow a house.
Old Jul 31, 2003 | 09:52 PM
stonework's Avatar
stonework
gear ratios
i hear you quadzilla. so would installing different gears in the differentials be the thing to do?
Old Jul 31, 2003 | 10:05 PM
theologian's Avatar
theologian
gear ratios
I need to get taller tires Today I checked very carefully and I am getting a hair over 75 at 2000 rpm. That is with 4.10:1 gears, and the aux in high. If I got taller tires the truck would look good, and I would probably get over 19 mpg.. How tall a tire will fit without lifting anything - I can't do any more serious mods to the truck for a while - I just spent a bundle on it, and my wife is only so understanding.
Theo
Old Jul 31, 2003 | 11:16 PM
gunfrk's Avatar
gunfrk
gear ratios
Hey Theo,
What kind of Aux? I have a '99 dually with 4.10's and at 2000, I'm at 63.
Old Aug 1, 2003 | 09:33 PM
theologian's Avatar
theologian
gear ratios
I have a US Gear overdrive unit - It makes an amazing difference - today I was at 2100 rpm, travelling at 80 mph. with the stock ratio I would up near 3000 rpm at that speed. I do not use the low side of the aux except for really fast take offs (380 hp makes for spinning tires with 4.10 gears.) or for towing in the mountains.
Theo
Old Aug 4, 2003 | 07:47 AM
bigbird1's Avatar
bigbird1
gear ratios
I am not familiar with this overdrive gear you are speaking of. Can you explain in detail or give me web site. thanks
