PO 302 Code????
Old Jul 5, 2015 | 05:07 PM
kermmydog's Avatar
kermmydog
Question PO 302 Code????
I know this is a truck forum but a 4.6L is the same.
On my 99 Crown Vic P71 4.6L I took a 1000 mile trip. On the way back I got awful gas mileage. I filled up at a Fast Strip station in Arizona I have never got bad gas there before but have heard a few stories of bad gas there over the last year. Well I got gas just before the tanker dropped a load. My mileage went from normal 17.9-18.2 mpg to 15.95 mpg. First thought was bad gas. So next fill up was at Union 76 & a can of Seafoam. NOTE (we made this same trip every month or so.) Well just before the we made the second fill up 180 miles later the CEL came on. I read it, a PO302 but mileage was improved a little below normal. So filled it up again with Union 76. drove home 103 miles home, looked like everything was OK on Thursday. Today Sunday 150 miles on fuel I get another PO302 code.
I put in new Autolite plugs, & wires, or boots about 10,000 miles ago. I have had a lean bank codes on the same side & it turned out to be an exhaust leak at the manifold. The top bolt likes to back out.
Where should I look for this random PO302 problem???? Note: normally if I get a misfire I feel it,but not with this condition.
Tomorrow I was going to change fuel filter it is over due, last changed about 25,000 miles ago & check the manifold bolts.
Sorry about the long post would appreciate any ideas or help.
Old Jul 6, 2015 | 05:56 AM
JWA's Avatar
JWA
That code is: "cylinder #2 misfire" which I'm assuming you already know. If its a persistent problem even after changing the plug, boot and COP then look to the wiring harness connector into the COP. Those have been known to lose contact due a broken locking tab and cause your sort of issue.
Old Jul 6, 2015 | 11:59 AM
kermmydog's Avatar
kermmydog
Smile
Thanks for your input.
Last night in the middle of the night the thought of a bad connection or a coil going bad came to me. So far it has come on twice in about 400 miles. But the last time I lost a coil I felt the miss fire. Last night I took it out & put my foot into it ran it WOT through the gears no miss felt no CEL. So I'll check the harness. Checked the connection it was solid so I put some Di-electric grease on the connector, so we will see. Thanks
Old Jul 9, 2015 | 11:18 PM
kermmydog's Avatar
kermmydog
Code PO302 is still haunting me. I changed the plug, new PCV valve. I'm running AP104 Autolites. Which are a platinum plug. It is a direct crossover from the OEM Motorcraft. Motorcraft's are hard to find. Anyway started it up after plug change & still showing a misfire #2 cylinder. So I decided to swap #2 & #3 coils. So far the jury is still out.
Any ideas from here. I checked connections on coils & injectors.
Old Jul 10, 2015 | 10:58 AM
JWA's Avatar
JWA
If P0302 continues coming up you know there's a problem with that circuit somewhere along its path back to the ECM.
If P0303 comes up you'll know its in the COP or its boot.
Old Jul 10, 2015 | 12:17 PM
kermmydog's Avatar
kermmydog
The PO302 keeps coming it it appears. It hasn't thrown the CEL but my reader keeps detecting it. The funny thing is I can't feel a miss so it is something that appears to happen even at idle but I can't feel even a slight miss. Every miss before has been a noticeable miss.
So where do I start? It sounds like it could be in the ECM? It happened all of a sudden. It ran great up to the point of the CEL.
Thanks for your response. I'm about to give up on this car. I bought it cheap $450 & put a few thousand in it, but it seems like it wants to start nickel & dime me to death. I have put 30K on it in less than a year & a half. Once my friends estate comes out of probate I have spoken for his 01 Crown Vic P71. Maybe I'll just take the new tires & stuff off this one & put it on the 01 which has less miles (155,000) & runs much better mainly because it was taken much better care of by the County that owned it than the County that owned mine.
Old Jul 10, 2015 | 05:05 PM
kermmydog's Avatar
kermmydog
On another forum it was suggested to check FI connection & if loose to replace. Well the #2 connector had a broken lock clip. So since I had to order new connector I thought I would use a plastic tie to hold it on tight. Well it appears to of stop throwing codes. So I will drive it and see if the CEL comes on again. If this fixes it I might plastic tie them all.
Thanks for the help so far.
Old Jul 13, 2015 | 09:50 AM
F150Torqued's Avatar
F150Torqued
Smart move. Those little plastic latches get brittle on about all our connectors > 10 years old and it only takes a momentary loss of connection for the ECU to detect it / set a code. And they charge insane prices for them.
Sounds like your new connector will solve the problem.
Old Jul 14, 2015 | 11:32 PM
kermmydog's Avatar
kermmydog
Unfortunately it didn't fix it as I had hoped. So I checked the air filter & it was dirty 30K on it & high desert dust & dirt.
Then I added 8 ozs. of 91% rubbing alcohol to the gas tank. Yesterday we drove 170 miles on the road & in town & No CEL. So maybe that was it. I do know my 99 Crown Vic P71 will set off the CEL without much effort. A slightly loose exh. manifold to pipe bolt caused a lean bank code & O2 sensor code. The bolt only would turn about a turn.
Oh the gas mileage was back up to 22 mpg.
Old Jul 24, 2015 | 02:37 PM
kermmydog's Avatar
kermmydog
Wrong thread.
Tmurphy38
1997 - 2003 F150
May 6, 2019 06:18 AM
Marty1965
1997 - 2003 F150
20
Jan 12, 2018 08:02 PM
mtmcall
2004 - 2008 F150
Jan 16, 2016 12:48 PM
al52269
Sep 14, 2012 08:44 AM
natsoundup
Jul 1, 2007 03:45 PM
