Battery Corrosion
Old Jul 1, 2015 | 03:11 PM
KDAVID1's Avatar
KDAVID1
Battery Corrosion
So I've been having corrosion return after cleaning pretty quick. Alt is putting out normal and batteries are holding up. The issue is the divers side positive is getting corrosion and the passenger side negative is getting corrosion. I am going to be replacing the positive cable (have on hand) and now will be getting a negative one for the passenger side. My question is--without replacing the whole system-cables, batteries, and alt--what is my issue causing the corrosion? Or what direction do I need to look in.
Old Jul 1, 2015 | 03:18 PM
dannyboy950's Avatar
dannyboy950
That is useually a sign of a constant draw on the system. How much of a draw and where will be a bugger to find sometimes.
Old Jul 1, 2015 | 03:39 PM
69cj's Avatar
69cj
Go to Napa and get a can of Noco NCP-2 battery corrosion protectant. Clean the cables real good and then spray the connections with the Noco. Best stuff I have found for this
purpose. Had the same problem on my 05 and this stuff stopped it dead. I'm now using it on my 2015.
Old Jul 1, 2015 | 03:46 PM
KDAVID1's Avatar
KDAVID1
That I don't like I doubt I would be able to find it. Wouldn't know where to even start looking/testing.
That's the thing--I did that a few months back--then it came back, did it again and the driver side pos. has not been as bad but the pass. side neg. keeps coming back with force (worse than before)
Old Jul 1, 2015 | 03:47 PM
WatsonR's Avatar
WatsonR
Vasoline will work also. Clean the negative ground on the frame, it's a sign of over charging as well, batteries getting weak.
Old Jul 1, 2015 | 03:51 PM
KDAVID1's Avatar
KDAVID1
That's kinda what I was hoping--kinda. So with battery getting weak--the alt will overcharge trying to get the battery to where it needs to be?
Old Jul 1, 2015 | 04:07 PM
dannyboy950
Thats what I was getting at even a small draw is still a draw lowers the battery eventually. You seldom notice it unless it is several days without being restarted.
If you start it will cause the alt to recharge the battery more than normal to keep the battery up because part of its charge is being drawn off. It never really reaches full charge.
Old Jul 1, 2015 | 04:21 PM
69cj's Avatar
69cj
If the corrosion has gotten inside the cable insulation it's more than likely too late to save the cable. It will continue coming back. Danny is also correct about the vaseline. The Noco imho however has a better chance of seeping into the cable at the insulation if it isn't already too late.
Old Jul 1, 2015 | 04:59 PM
WatsonR's Avatar
WatsonR
Take the cable end and put it in a coke, it will foam at first and then dig in cleaning. Leave it about 8 hours and rinse with water, then apply whatever to the connection and battery post. We used in in the Navy to clean brass and copper, it will eat anything on the copper up inside the wire cover you can't get to.
Old Jul 1, 2015 | 06:10 PM
jsm180's Avatar
jsm180
It's possible your terminals are leaking acid, one of my interstates pushed the positive terminal up enough to leak.
Old Jul 1, 2015 | 06:41 PM
KDAVID1's Avatar
KDAVID1
Battery Corrosion
Terminal or the post?
Would baking soda do as well or does the acid on coke add the extra kick. I have used coke before for a quick clean but not a soak.
Old Jul 1, 2015 | 07:36 PM
jsm180's Avatar
jsm180
The lead chunk sticking up out of the battery, it's connected to the lead plates in the battery. If the seal breaks between terminal/post/lead chunk and the case, acid will leak out. If it's leaking, putting baking soda on it is not going to do your battery any favors.
Old Jul 1, 2015 | 07:40 PM
WatsonR's Avatar
WatsonR
Soda goes dead to quick. I'm talking disconnect the connector and swing it away from the battery before soaking, soda in a cell is bad.
Old Jul 1, 2015 | 08:11 PM
KDAVID1's Avatar
KDAVID1
Battery Corrosion
Gotcha.
Yea that's how im going to do it.
Not worried about the batteries now--decided I'll just change them out. Will buy some coke to soak the passenger side negative terminal in, put the new positive cable on, and dress the new batteries with the red stuff. Was wanting to wait a little lo ger but the corrosion is bugging me. Least all I'll n3ed now is the alt upgrade and charge cables.
Old Jul 2, 2015 | 10:49 AM
dannyboy950
That old coke trick has been around awhile. WWII at least my dad started doing that after comeing back from WWII [Navy]
But it does work well.
