I have been looking for the dually fender fasteners and found this place. They did not have the fender bolts, but they had some cool stuff. I ordered a bunch of those plastic rivets, oil plug stuff, etc. They also have the valve cover gasket and wiring loom for out trucks. I have not received the items, but they shipped them the next day.
I have found the fender plastic bolts, but they (ford) want 15.00 each, ouch, and yes I am a cheap ***.
That's not cheap ***, paying those prices would be INSANE!
Even if you found something else that would work, and replaced all of them so they matched, in my book is just smart.
Good luck.
They don't have every item, but I go to the www.fordparts.com web site and look for the part and then run that number, if that does not work measure the fastener hole and determine the head size needed, then order. If you can't find the correct color, just use some Fusion paint
