E150 trailer connector help
Old Jun 29, 2015 | 07:00 PM
Markr60's Avatar
Markr60
Hello all
I recently bought a 1995 Club Wagon , an E150 with 5.8 v8 motor. The Ford dealer looked the vin up for me and tells me it has the factory tow package.
I need to tow a small trailer soon so I need to find out what I need to connect the 4 wire trailer connector to the truck side. The car I used for this was wrecked and my new used car is a 1998 ford taurus. I was advised not to tow with that.
The connector looks to have 6 flat pins and a center terminal.
I looked under the truck for a 4 wire connector but couldn't find one.
There is also a connector near the trailer wiring connector that looks like a two flat blade connector. Any ideas what that is for ?
It has over 250,000 miles on it so I dont expect to pull much weight but its going to be short trips with maybe 1200 pounds on the trailer.
thanks.
Old Jun 29, 2015 | 09:46 PM
Spaznaut's Avatar
Spaznaut
Can you post a picture of it? Usually you can buy a wiring harness tee splice (not the real name) that will fit between a connector in the rear harness.
Amazon.com: Tow Ready 118344 T-Connector for Ford FS Van 92-02: Automotive Amazon.com: Tow Ready 118344 T-Connector for Ford FS Van 92-02: Automotive
Old Jun 30, 2015 | 09:13 AM
GreeVan's Avatar
GreeVan
I just use an adapter :
7 to 4 pin adapter. 7 to 4 pin adapter.
TomDillard
May 10, 2014 12:04 AM
plumberpete
Dec 18, 2011 07:14 PM
njxlt
Aug 10, 2004 06:54 PM
