Check engine Code
Old Jul 30, 2003 | 10:58 AM
okcexpo's Avatar
okcexpo
Question Check engine Code
I took my 98' 4.6 4x4 Expo to Auto Zone to have my check engine light looked at to get the error code. They told me it was a dealer specific code. Does anyone know what P1401 error code means? It also showed this message along with that error code: DPFE EGR Circuit High Input. Help.
Old Jul 30, 2003 | 05:17 PM
buzzard's Avatar
buzzard
Check engine Code
Something with the DPFE sensor and the egr valve. The sensor communicates info between the EGR and the PCM. Sorry I don't have more info that this. You might try a web search of "P1401" and see what you come up with.
Old Jul 31, 2003 | 09:24 AM
okcexpo's Avatar
okcexpo
Check engine Code
Thanks I'll try searching for it on the web. Would you happen to know how difficult it would be to replace either one of those?
Old Jul 31, 2003 | 09:35 AM
buzzard's Avatar
buzzard
Check engine Code
I couldn't imagine too hard since the egr is on the top of the engine. I've heard others complain about the DPFE sensor saying it is an antiquated part so you might want to start with it.
Old Jul 31, 2003 | 09:39 AM
okcexpo's Avatar
okcexpo
Check engine Code
I searched the web and found this definition of P1401: Differential Pressure Feedback Electronic Sensor circuit High Voltage. What does this mean and how can I fix it? I just want to get all the info I need before I take it to the dealer and put it on thier diagnostic machine.
Old Jul 31, 2003 | 06:40 PM
jonmech's Avatar
jonmech
Check engine Code
p1401 is a high voltage sensed on your dpfe circuit.
the problem most of the about 95% OF THE TIME IS THE DPFE, SO WILL TELL YOU TO REPLACE THE DPFE
