fuel tank issues
Old Jun 27, 2015 | 03:26 PM
mattjarma's Avatar
mattjarma
fuel tank issues
So I bought a new tank from LMC Truck and it has what appears to be a 3/8 opening in the back of my tank to thread the fuel line into. Someone had a plastic boat fuel cell in it before. They didn't hack up the metal fuel line, though. Problem is, looks like I have a 1/2 inch fitting to try and screw into a 3/8 hole!! Anyone run into this and if so, how to find an adapter to make this work?!?!
Matt Jarma
Temple, TX
54 F350 Script Bed, original 223 with original 4 speed
Old Jun 27, 2015 | 06:57 PM
FortyNiner's Avatar
FortyNiner
I'm a bit confused. The 1/2 inch boat connection was used with the old tank?
Old Jul 6, 2015 | 06:06 PM
mattjarma's Avatar
mattjarma
This is my 3/8 opening, I assume. There isn't enough clearance for me to measure it.
This is my 1/2 inch fitting that needs to thread into the back of the tank. I assume there is an adapter for this to work?
Old Jul 7, 2015 | 07:46 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Check with NAPA. They will have a brass fitting that's 3/8 on one end to fit the tank and 1/2 inch on the other to allow the fitting to go in.
Old Jul 7, 2015 | 01:43 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
That brass fitting pictured is not a factory fitting. Just go get one that will work for your application, as stated.
Old Jul 7, 2015 | 02:25 PM
gerrymoe's Avatar
gerrymoe
Not being able to distinguish the actual size of the fitting in the new tank, I will offer up what I know of the subject. I believe the weld bung in the tank is either 1/4 npt or 3/8 npt, my guess here is, it looks like 1/4 npt to me. Beings that I have never seen a truck with 1/2" fuel lines I will say that the supply line is 5/16 with a male 5/16 inverted flare. So take the fitting out of the gas tank and take it to Napa and tell them you want a fitting similar but to have the same npt threads as the one you have and on the other end have female 5/16 inverted flare threads. At this point it will be just a process of elimination, but should only involve a couple trips to Napa
blue76
Jul 2, 2016 06:16 PM
hubler13f
May 8, 2016 11:20 PM
410 Highboy
Dec 23, 2013 06:18 PM
BACAGrizz
Sep 29, 2010 12:03 PM
