Steering Wheel Wobble??
Old Jul 30, 2003 | 10:45 AM
MPDano's Avatar
MPDano
Exclamation Steering Wheel Wobble??
I have a 1997 Expy and I am starting to get steering wobble around some turns. It depends on the degree. It happens in both left and right turns. Any suggestions? I was looking around the suspension, but didn't see any bad bushings. I recently put new shocks, but the shaking was from before this. I am new to this forum, thanks in advance
Old Jul 30, 2003 | 01:40 PM
ppo2's Avatar
ppo2
You may want to first check your alignment and balancing. I have the same feeling about something beeing loose. Mine happens on straight aways usually around 65 mph and above although I've had my tires rotated, balanced and even aligned. I also feel that my steering feels kinda loose. I too have put in new shocks and have always checked my tire pressure. We may have something similar going on.
Any takers out there? I'd appreciate any feedback or suggestions
Dan
Drive Safe
Old Jul 30, 2003 | 08:20 PM
97expy5_4's Avatar
97expy5_4
This is a really common problem with the early Expy's.... Mine did the same thing. I then installed Rancho 5000 shocks, Goodyear ATS tires, Hellig rear sway bar. This fixed the problem, but now at about 71,000 miles the wobble is coming back. The tires have 44,000 miles now and I'm taking it to Cosco for an alinement and balance ($16.00) I'll post the results....
Big Mick
Old Jul 30, 2003 | 11:55 PM
MPDano's Avatar
MPDano
Yes, please let me know if the alignment worked. I am hoping its that simple
Old Jul 31, 2003 | 06:17 AM
ppo2's Avatar
ppo2
Big Mick
Yes, please do. BTW I forgot to mention that my truck's a 99 XLT with 24,000 miles on my Yokohama Geolandar tires. I had my rims checked to make sure they weren't warped. I'll try and see if they go away if I rotate my tires - if they do then it's gotta be something with the rims, although I know they're not warpped. If after I rotate and it's still there, then I know it's gotta be the front end. I installed the Monroe Flex shocks early this year and even checked everything under the truck to make sure nothing is loose. Oh boy
Drive Safe,
Dan
Old Jul 31, 2003 | 01:31 PM
scottpower's Avatar
scottpower
Be sure to check the steering shaft, from the wheel, yoke at the steering box. If it has free play in any direction, post it here. The yoke connecting bolt can be installed wrong. It was a recall on the older 97s but my late 97 had the problem. Shouldn't show up on newer ones but???
Old Jul 31, 2003 | 01:35 PM
MPDano's Avatar
MPDano
How can I check if this is a good recall for the 97 Expy?? Thanks
Old Jul 31, 2003 | 01:56 PM
scottpower's Avatar
scottpower
Recall # 03S02. Applies to various VINs built at all 3 plants through late '96. Don't let them say it is an F-150 recall. Make them read the small print. It includes EXPYs. If your vin is not included (the NTSB reports say '97 & '98 trucks) maybe they will give it a look for free. It is a simple inspection. Mine did although my EXPY was built in Jan '97. It was bad, turned the bolt and much better although a little play. Dealer is bugging Ford for new parts but losing. I will have to bitch at them I guess. Anyway, look yourself if necessary. The yoke has a plastic cover over it. The clip holding it is not the ones you can see from underneath. The clip is on the top but you can feel it and release it easily from underneath. Push the cover up the shaft and try to push/pull the yoke/shaft on and off the input shaft. Should not move that way or any way without turning the input shaft. If it does, the bolt holding it on the shaft may be installed backwards (mine was). If just a little loose, push the dealer for inspection/parts.
Old Jul 31, 2003 | 02:35 PM
MPDano's Avatar
MPDano
I found a link to this recall:
http://www.arifleet.com/Recall.html
http://classaction.findlaw.com/recal...3/pr29-03.html
Old Jul 31, 2003 | 08:21 PM
deanjet's Avatar
deanjet
I had a set of cheap tires cause that problem. Ford said the belts had seperated internally on my original tires. Ford replaced the tires under a recall.
Old Aug 1, 2003 | 06:23 AM
ppo2's Avatar
ppo2
Deanjet,
Talking to my younger brother, he says the same thing happened to his BMW. Cheap tires caused the wobble and no balancing nor alignment could fix it. Belts did break internally. Question is, can you visually see by looking at the tires if the belts separated internally? How did the Ford guys know, short of a recall on the tire? Tires aren't a cheap solution you know. Thanks for the reply, now you got me thinking.
Thanks also for everyone's input, good or bad they all matter.
Drive Safe,
Dan
Old Aug 1, 2003 | 07:54 AM
MPDano's Avatar
MPDano
Thats got me wondering too. I also bought a set of tires from Discount Tires made by General.
Old Aug 1, 2003 | 07:33 PM
deanjet's Avatar
deanjet
I have no idea how the Ford tech determined that the tires had belts seperated internally. The tires looked to be wearing fine to me. I supose it was just experiance that drew them to the conclusion that the tires were bad. Perhaps they took a test drive and thats what tipped them off.
Old Aug 1, 2003 | 07:49 PM
Machek's Avatar
Machek
I had a steering wobble on my 4WD '98 and it turned out that the stabilizer bar links were broken. It was a cheap fix at the tire dealer, and at 70K miles, still drives straight and smooth.
Old Aug 1, 2003 | 09:08 PM
MPDano's Avatar
MPDano
The stabilizer links are on the rear? And this made your steering wobble? I will check this tomorrow. Thanks
