U-joint with grease fitting
Old Feb 25, 2002 | 09:15 PM
WB9PRG's Avatar
WB9PRG
Does anyone else use these U-joints with the grease fitting ?
I have been very pleased with them.
Gene
1996 F150 4x4 ext. cab
Old Feb 25, 2002 | 10:21 PM
cmlind's Avatar
cmlind
I replaced mine with greasable ones. I like them much better even though you have to climb under to grease them. It is better to have to grease them than to wonder if there is still grease in the non-serviceable ones. They last longer too.
Old Feb 26, 2002 | 01:09 AM
Ryan50hrl's Avatar
Ryan50hrl
The greaseable u-joints are not nearly as strong. They have the hollow inside where the grease resides, while the non-serviceable ones are solid. For those of us that use our trucks hard, go with the solid non greaseables, for those of you who rarely go wheeling, pull heavy loads, or do clutch drops, the greaseable ones would probably suit you fine.
Ryan
Old Mar 3, 2002 | 12:48 AM
jreed's Avatar
jreed
i replaced all of my u joints with grese fitting ones, about 3 weeks i chirped all 4 33x12.50's on dry pavement trying to pull out a tree,also i lay the hammer down in deep mud swamps. i love the u joints with grese fitings. 5.0 also
john reed
Old Mar 4, 2002 | 08:56 PM
Greg Carter's Avatar
Greg Carter
I've never broken one, and I use my truck pretty hard. I actually seek out the greasable kind, since if you off road in any kind of mud or water, being able to grease the joints will allow you to get all the water out. I am always amazed how much water squirts out when I grease my truck after off roading.
Greg.
Old Mar 4, 2002 | 09:25 PM
Ryan50hrl's Avatar
Ryan50hrl
If you do use the greaseable u-joints, you should never put enough grease into them to push stuff out of the seals, doing so breaks the seal and it will no longer do what it is designed to do, if you do use the greaseable u-joint, put just a bit of grease into them, not pump them full. Have fun wheeling.
Ryan
Old Mar 4, 2002 | 09:31 PM
Fun in a Ford's Avatar
Fun in a Ford
Go with the greasable ones if you dip in the mud and water often, or even occasionally. But if you do alot of heavy duty pulling (stump pulling, off-road retrieval) go with the solid ones. They are more unlikely to break under high-stress situations. If you don't use your truck too hard, I would go with the greasable ones, they generally last longer due to the fact you can regrease them.
Old Mar 5, 2002 | 12:35 PM
mickelsons's Avatar
mickelsons
>fun wheeling.
>Ryan
I am sory I have to disagree with you on this one I am a certified mechanic and those rubber seals are accually designed to purge out the contaminants you should be greasing them until you see clean grease come out the seals that way you get all the water and crap that might seep in. the seals are designed to alow the grease to flow out but not come back in.
Not to start an argument, I am sure everyone has there own opinion on the subject but the paper work that comes with ours on the trucks I work on specify to grease them this way.
Scott
Old Mar 6, 2002 | 12:25 AM
stevieray's Avatar
stevieray
I agree with Mickelsons... pump grease in till you see it come out from around the seals thus purging any contaminates that may have got in. This also goes for ball joints and tierod ends. Grease is cheap anyway. As for the grease passage weakening the structure of the U-joint I have never seen one break from excessive rough use but have seen them fail from lack of grease inspite of the grease fitting, neglect on the owners behalf.
Old Mar 6, 2002 | 03:16 PM
GammaDriver's Avatar
GammaDriver
I'll have to agree, also, with the posts on greasing these parts until clean grease comes out. If it were the type of seal that wasn't supposed to be greased-out, it wouldn't come off with the caps so easily.
Funny we're talking about this - I just put a "PRECISION" brand U-joint in the rear of my truck this morning. Thankfully I had the unexpected help of a pro mechanic (and friend of the family) who dropped by with the most unbelieveable good timing.
I pounded and pressed while trying to get it out, but the caps really weren't moving much after the first few millimeters. After a bench-vice and heating of the driveshaft's flanges it was still a no-go. Finally we took it outside and he used an acetylene torch to cut the U-joint out. Impressive! (In doing so he saved me at least two hours work, if he didn't save me from total failure!)
The caps were easier to hammer out toward the inside with the U-joint gone.
No more vibrations atover 55 MPH, and no squeaks either.
I learned I've got to be less afraid of torch-cutting old parts out.
Old Mar 8, 2002 | 12:19 PM
brett6324's Avatar
brett6324
With 35x12.50 on my rig I was cracking greasable ones about every 6 months with mostly highway miles, went to the solid one about 2 years ago and no problems
Old Mar 8, 2002 | 02:29 PM
Pastmaster's Avatar
Pastmaster
