Increase the range
Subscribe
Jun 21, 2015 | 11:22 AM
I have a 2001 F250 with 5.4 V8 Gas. When I tow my camper, I can go about 100 - 130 miles before I need to start looking for gas. I cannot stand that range, so I want to increase the range. There are plenty of options for diesel. What options do I have that is reasonable? I saw a tank that cost close to 2K and it replaces my stock tank, but that is not worth it. Is there any other reasonable option?
Reply 0
Jun 21, 2015 | 12:02 PM
Have you looked into the aftermarket "saddle" tanks? I had one on my old Dodge Powerwagon, which helped a lot since it got 6 mpg unloaded.
Found this one, it's not an additional saddle tank, it replaces your stock tank. 55 Gallon. It's $945 I think.
http://www.aerotanks.com/inventory/1019.html
Reply 0
Jun 21, 2015 | 01:19 PM
Quote: Have you looked into the aftermarket "saddle" tanks? I had one on my old Dodge Powerwagon, which helped a lot since it got 6 mpg unloaded.
AeroTanks - Ford 1019
That tank is for diesel only according to their list.
Reply 0
Jun 21, 2015 | 02:09 PM
Try looking under transfer tank in Google. Found some but iPad won't let me send it to web site.
Reply 0
Jun 21, 2015 | 05:19 PM
Excursion tank swap?
https://dl.dropboxusercontent.com/u/...350%20tank.pdf
https://dl.dropboxusercontent.com/u/...re%20mount.pdf
Titan fuel tanks:
https://titanfueltanks.com/product-c...lter_make=6662
Reply 0
Jun 21, 2015 | 05:32 PM
Titan Fuel tanks are for diesel only.
I have to take a close look at the Excursion Tank swap. I have never done the scope of that work, but it may be something I can do.
Reply 0
Jun 21, 2015 | 06:28 PM
What is that like 5mpg?? Worst I ever got with my 05 V10 F350 towing a 10,000 travel trailer and 2 quads in the bed was 6.7mpg. That was uphill all the way as well.
Reply 0
Jun 21, 2015 | 06:38 PM
Quote: What is that like 5mpg?? Worst I ever got with my 05 V10 F350 towing a 10,000 travel trailer and 2 quads in the bed was 6.7mpg. That was uphill all the way as well.
Big difference between V10 and V8. I had V10, and it stayed in OD most of the time. With my V8, it stayed in the 2nd gear most of the time in Texas hill country. The only reason I have V8 now is because I totaled my V10 truck on black ice. I was not able to find another V10 in my price range, so I went with this truck.
Reply 0
Explore
Jun 21, 2015 | 06:40 PM
20' trailer against a 40 mph head wind on I-80 heading into Reno I managed 5.5 and between towns ran out of gasoline.
The tow service charged $200 to bring out 5 gallons of gas.
Reply 0
Jun 21, 2015 | 07:24 PM
What gears do you have in the rear end? Have you updated to the SPD y pipe? Is your truck a short or long box?
Reply 0
Jun 21, 2015 | 07:25 PM
I've only seen the tanks as you describe. In the $2k range. And they're only painted steel.
One member, rvpuller, did an interesting hookup for extra fuel but it's more based around hauling a 5th wheel camper so it takes up a lot of bed space.
So yes, you're screwed with paying a premium to allow extra fuel. If you frequently travel it may be worth the expense.....
Reply 0
Jun 21, 2015 | 07:27 PM
Quote: What gears do you have in the rear end? Have you updated to the SPD y pipe? Is your truck a short or long box?
I don't have a welder to do the y pipe thing. Besides, what will that do with the range? I have shortbed and the gear is 3.73.
Reply 0
Jun 21, 2015 | 10:28 PM
Have you thought about going to a 4.30 gear ratio? Do you have stock size tires? Y pipe is for power and supposedly economy. Was thinking it may help your truck be a little more efficient.
Reply 0
Jun 22, 2015 | 01:46 PM
dont know how much help this is, but.... ever though of carrying 4, 5 gallon military gas cans with, they are rectangle so they fit up next to cab nicely. wont be as nice as a bigger tank but would increase range with trailer a while.
Reply 0
Jun 22, 2015 | 03:14 PM
Increase the range
Your cheapest option will be an in bed tank option. However even these options will be around $1000 minimum.
A short bed 5.4L is not the best option for towing. Especially with 3.73 gears, which is another $1000 to upgrade (fix).
Would it be possible to take the $1000+ and invest it in a down payment. Possibly with your current truck for trade?
Reply 0
