freon line filter ??
Old Jun 20, 2015 | 06:02 AM
bigcrunch's Avatar
bigcrunch
Is there one avail to add to the low side on a 2006?
Old Jun 20, 2015 | 08:11 AM
Skauber's Avatar
Skauber
Is there a specific reason to why you want to add a filter on the low side?
Old Jun 20, 2015 | 08:59 AM
bigcrunch's Avatar
bigcrunch
bad compressor replacement.
So is there a filter?
Old Jun 20, 2015 | 10:33 AM
alloro's Avatar
alloro
The accumulator/dryer is a filter.
Old Jun 20, 2015 | 11:08 AM
bigcrunch's Avatar
bigcrunch
probably why no more orifice filter ,,, ??
Old Jun 20, 2015 | 11:09 AM
Skauber's Avatar
Skauber
If you had a compressor going bad and pumping debris into the system, you need to replace expansion valves, condenser and in worst case scenario also the evaporator(s), and flush the lines. The accumulator/dryer is also a filter, and will have to be replaced as well, regardless of there being debris or not. There's no need to add any extra filter to the system.
Old Jun 20, 2015 | 03:42 PM
83sd's Avatar
83sd
They do make them, But they are unnecessary. Do the job right from the beginning and there will be no issues. A filter might catch debris, but after trapping them, it may start to restrict flow.
PirateGhost
Sep 27, 2011 08:26 PM
Iceman31
23
Mar 9, 2007 11:07 AM
