2010 F150 King Ranch Roof Leak
Headliner over the back seat on the driver's side of my truck.
wet leather rear seat.
I have a 2010 F150 King Ranch 2 wheel drive pickup. Last night we had a lot of rain here in Texas. When I got into my truck to go to work this morning I found that the backseat was all wet!! I thought that I had left the moonroof open however upon closer inspection, I hadn't. The back sliding rear window was not open either. I read a few posts here that talked about ensuring the drain lines were free of obstructions so I did that and found that the driver's side front moonroof drain line was not hooked up. However, when I was testing it, the water was leaking in the front driver's side door...not the back seat area. I fixed that drain line so that wouldn't leak but I don't know where the leak is that would cause the back seats to get so wet??? They are soaked as you can see from the picture. Upon further investigation, I found that the rear headliner over the back seat is soaked. The leak seems to be worse on the driver's side of the cab than the passenger's side. I noticed on top of the cab close to the rear of the cab of the truck a rivot in the channel. Would that leak? If anyone else has had this problem, would you tell me what you did to fix the problem? I would appreciate any advice on how to fix this problem.
Crystal
I 2nd the third brake lamp.
The bolt in rear windows have also been known to leak, around the outer frame and around the 3 panels. This can also be exaggerated if you have a fiberglass cap on the truck, but that is only while moving. The cap changes the air pressure against the back glass, forcing water inside while moving.
big_colo
1983 - 2012 Ranger & B-Series
11-17-2008 09:29 AM
