So I purchased a new 8ft bed.
I bed takeoff back from 1994 ($800)
My question is where can I buy new bolts from a hardware store? Since I cut off the old ones. Ty
Hardware stores tend to not have automotive bolts....I am sure you could replace them with something similar from a hardware store though...
Autoparts stores and aftermarket stores should have them though...
Two options: SD bolt kit which is usually well over $100.
8 grade 8 1/2" bolts, washers and nuts. You need 4 long and 4 short. I don't recall the exact lengths. If no one chimes in, I can measure my old factory bolts. I paid like $20 at fastenall for mine.
The problem with the OEM clips/nuts is they are not really nuts. They are soft metal designed to allow the bolt to cut threads into them. Look it up. That's great at the factory from an assembly standpoint. However, when you go to DIY or take it apart, you need air tools to actually get them moving; hence, the breakage. I'd much rather crawl under my truck with a wrench to hold a grade 8 nut still while a helper loosens 8 bolts than fight with trying to unstuck the super duty bolts (been there, done that!).
Finally!!. Someone else who has had to REMOVE them
