Need help
Old Jun 15, 2015 | 08:39 PM
Mbg319's Avatar
Mbg319
Need help
Hi everyone this is my first post. I have a 95 f150 with 5.0 and eaod. It has 99k miles. It has no power under load. I have replaced plugs and wires. Rotor and cap. It ha s no check engine light on. When hooked to my boat it pulls it with overdrive switched off but shifts funky and it has slipped a few times when shifting but only when it's been ran several miles. With out a load it seems to run fine although it's no hot rod. But it won't pull boat up a boat ramp. It feels like it's in 2nd or 3 rd gear it just bogs down. I checked the tps and it checks ok. I think it might have a small vacuum leak some where as the ac switched from dash to floor to defrost going down the highway. Any ideas would be greatly appreciated as I need to fix this myself financially.
Old Jun 15, 2015 | 09:47 PM
anthonym92's Avatar
anthonym92
check for codes to see if anything comes up. but i would check your timing.
Old Jun 15, 2015 | 09:51 PM
F350 1990's Avatar
F350 1990
Sounds like you used a multimeter to eliminate the TPS and that's a good start...........since it's an AODE (electronic) it's likely a sensor (e.g. VSS, Transmission Range (MLPS), etc) or internal damage ---when did you change the fluid/pull the pan last?
Old Jun 15, 2015 | 09:58 PM
Mbg319's Avatar
Mbg319
Need help
I changed the filter on the transmission last summer. The oil looked good and
clean.
Old Jun 15, 2015 | 09:59 PM
Mbg319's Avatar
Mbg319
Ok I'll check the timing thanks
Tim Morel
1978 - 1996 Big Bronco
Apr 13, 2016 05:03 PM
pop's 4X4
Aug 5, 2010 04:50 PM
rdaniel9111
Feb 13, 2007 10:32 AM
cuztom79
20
Jan 26, 2007 08:58 PM
PyroBob
Apr 25, 2005 04:35 PM
