Adding CB Radio
Old Jul 29, 2003 | 05:24 PM
YankeeHillbilly's Avatar
YankeeHillbilly
Question Adding CB Radio
I'm getting ready to install a CB in my 2002 F25O and would like to avoid using a cigarette lighter adapter plug for power. Could someone give me information on the proper way to tie into the fuse panel? Or for that matter any other good ideas (it will be mounted on the center console)
Thanks
Old Jul 29, 2003 | 06:47 PM
Mil1ion's Avatar
Mil1ion
Adding CB Radio
This has been discussed many times.
Myself I like to use shielded coax to power the radio directly to the Battery.
This usually guarantees less problems with any electronic devices like ignition & alternator whine.
You may look in this forum or the audio forum for other threads.
Old Jul 29, 2003 | 09:58 PM
YankeeHillbilly
Adding CB Radio
Thanks!
New to the board and didn't notice the audio portion.
Old Aug 4, 2003 | 10:42 AM
Steelheader14's Avatar
Steelheader14
Adding CB Radio
I would like to add a CB also. How/where do you pass the wires through the firewall? The only place I could find is one of the grommets under the steering column. It looks like I could pull the grommet out, make a slice from the edge to the through hole, lay the wires in there, and seal that up with some silicone?
Old Aug 4, 2003 | 10:57 AM
YankeeHillbilly
Adding CB Radio
I haven't made it that far just yet, temporarily running power through the cig lighter, once installed I realized that channel 17 is dead, so now I gotta run back to the radio shop and do a little fussin' .(Anyone have any ideas as to what could cause just one channel to not work?(cobra 29 NW ST) ). If you do find an ideal place how about posting it
Old Aug 4, 2003 | 01:07 PM
Mil1ion's Avatar
Mil1ion
Adding CB Radio
The best place is beside the speedo cable.
That should be a foam material.
The alternative thing to do is make a hole and get a grommet to fit.
ManfredVonRichtofen
1978 - 1996 Big Bronco
15
Jan 9, 2017 11:30 AM
cb_13
Testing.....
Dec 16, 2016 11:24 PM
1978crewcab
WTB - Parts & other
Apr 14, 2016 09:45 AM
cb_13
Testing.....
Feb 6, 2016 09:41 AM
ncycenas
Jun 2, 2013 09:07 PM
