73-79 Dentside parts, couple early bronco
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude
the best thing to do, is PM me, I guess.
Header Gasket & bolt Kit for a 351m / 400 for Hooker part Number 6902 New $5
C6 Auto Transmission. Pulled from 79 F150 4x4. Was driving fine prior to, but that was some years ago. $100
3spd w OD Manual Transmission with factory Floor Shifter. Pulled from a 79 F100 2wd. 145,000 miles. "ORION" is cast in the case. Tag Says " RUGCDCK28 D8TRMA4425" $100
460 Exhaust manifolds, from a 76 Lincoln I think. D5VE-9430-BA, D5VE-9431-AB $50
2" Body lift pucks, no bolts, set of 12 $30
High Hump Transmission tunnel covers, 73-79 4x4, Auto trans, 2 ea $20
3 spd manual transmission, I think this came out of my 65 F250 high boy 4x4. Has a rigid yoke like you'd see in a divorced transfer case. Case# C5AR 7008, Input bearing retainer/ throw out slider PN C5AR 7050B $75
3 spd Manual Transmission, out of late 60's Bronco. Worked fine. Owner upgraded to top loader 4 spd. It is missing the adaptor housing between transfer case. Case# C8AR 7006 B, Tag# RAN R1 K024433 $100
Dash Panel with speedo and gauges from '69 Bronco $100
351W Complete heads, Cores, many miles but ran, D5AE CA 351 are cast on bottom. $35
351W Complete heads, cores, many Miles, untouched, D0OE, fairly well desired head $100
351 W Complete heads, cores, many miles, D8OE AB $30
351 W block, D3AF-6015-BA. It Has newer style 1 piece rear mail seal. Think it needs to be a .030" over candidate. I can mic. the cylinders if you're interested. $60
351W Crank core. Need to be turned .020" $30
302 short block, Block, Crank, pistons, rods & oil pan. Core. Never been apart. D1OE-6015-AA block casting $60
79 2wd F150 Midship Fuel tank. Very nice original piece. $50
79 F150 rear fuel tank, 2wd (I think same as 4wd) Very nice original piece $40
79 F150 rear fuel tank, 4wd (I think same as 2wd) good solid tank, clean inside, a little dirty outside. $25
73-79 in bed side tool box. Includes the Door, hinges, bed side flange cut from previous truck, plastic liner box, hanging support. Not perfect by any means, the bad, plastic liner has small crack and a small hole, the hanger strap had been cut where the bolts mount ( easily repairable). The good, no rust on door itself, door is straight w no dents, latch works good. $75
73-79 pedal collection, 2 full sets plus, 1 set has clutch and power brake pedal, 2nd set has clutch and manual brake pedal. There is also another power brake pedal. There are many combinations of pedals for these trucks, I do not know exactly what these came out of, but there are Pn's for some one who knows. $25
79 F150 4x4 auto trans to column shifter linkage and pivot rod. $10
79 F series LH front turn signal housing $5
79 F150 2wd steering linkage tie-rods $30
79 F series Grill Shell dent free, w/ plastic grill insert. $300
79 series Head light buckets w/ plastics trim $40
79 series center grill support to Radiator support, hood latch mounts to this piece. $5
79 series radiator support, very solid light surface rust, V8 $50
79 series LH inner fender 4wd, Drivers side, has cut out for 4x4 steering box $30
Dana 44 front axle gear set, used but good condition, 3.50:1 high pinion $50
Ford 9" gear set 3.50:1, used but good condition $50
Ford 9' rear end from 1981 F150. Needs brake backing plates on out. $75
99 Grand Cherokee transfer case Core. It would bind up going around corners $30
bigdavesohc
07-10-2009 01:28 AM
Brian794x4
02-19-2007 08:58 PM
SDBASS-F150
04-18-2006 08:08 PM
