Shocks
Old Jul 29, 2003 | 04:34 PM
Poolpro's Avatar
Poolpro
Shocks
Hey guys I need to know how or where to measure to make sure I get the right shocks for the back of my 1956 F-100. Had to relocate shock holders on the rear end. Any Ideas???
Mike
Old Aug 1, 2003 | 01:14 PM
41Clay's Avatar
41Clay
Shocks
I'm bumping this thread.
Old Aug 1, 2003 | 01:39 PM
Earl's Avatar
Earl
Shocks
Hey 'fenders, didn't you go through this with your 53? Seems like you found the distance between the mounts with a "normal" load in it and then got some shocks that were about mid-range at that length???
Old Aug 1, 2003 | 10:23 PM
fatfenders's Avatar
fatfenders
Shocks
Yes, that's what I did. I put the vehicle on jackstands and measured it at rest. Parts store will have a buyers guide with travel range listed. The most important number is minimum length, or full compression. You should be able to measure how far your axle travels before suspension would bottom. One good bump can trash a shock at full compression. It is far less of an issue if your axle dangles by the shocks at full extension. If your truck is lowered much, your shock choices are very limited but you'll be able to find one to meet your needs. You can also use a larger rubber bumper to limit the axles travel.
