Turbo Issue?
Old Jun 8, 2015 | 02:36 PM
Bordeauxman's Avatar
Bordeauxman
Turbo Issue?
2005 F250 SD, Crew Cab, Diesel 6.0L...
Hauling my jeep (close to 16,000 pounds all in F250+trailer+jeep) on a highway going a little over 70mph up a hill when I seemed to have lost some power and the check engine light came on. The turbo PSI was well over 20PSI (according to the gauge in the dash). I have a Scan Boss but I have not been monitoring turbo boost PSI.
I was only 10 miles from the final destination so I continued without stopping. It seemed that the turbo was limited for the rest of the trip. Later in the evening, no more check engine light but I haven't really driven the truck since then.
What do you think the problem was? What should the course of action be?
Thank you in advance for your advice.
Old Jun 8, 2015 | 02:42 PM
KIDkiser's Avatar
KIDkiser
You need something to check for codes.
Old Jun 8, 2015 | 02:55 PM
Bordeauxman
FWIW, I did check for codes with my Scan Boss and it had not logged any codes.
Old Jun 8, 2015 | 05:04 PM
WatsonR's Avatar
WatsonR
Sounds like you may have over boosted. Watch VGT while driving unloaded, you shouldn't see 15 or 85. The VGT is a commanded value, not actual, if you see something like 20 and it doesn't seem to be giving boost and then all of a sudden it really goes, that may be the indicator of stuck vanes.
Old Jun 9, 2015 | 07:09 AM
npccpartsman's Avatar
npccpartsman
Was it a check engine light or wrench light?
Old Jun 9, 2015 | 08:16 AM
Bordeauxman
It was the "wrench" light.
Old Jun 9, 2015 | 08:52 AM
npccpartsman
I'm thinking you got a defuel from too high ECT/EOT delta's, which might indicate a plugged oil cooler. You need to monitor ECT/EOT temps and see what the difference is: not towing, on level ground, for at least a 10 mile run AFTER the engine gets up to FULL operating temperature.
Old Jun 9, 2015 | 09:17 AM
MC5C's Avatar
MC5C
There is a chance it's the oil cooler but presuming you've been monitoring that it's about 99% sure you have stuck turbo vanes. I had exactly the same symptom, pulled turbo, it was heavily rusted so I got a new Rotomaster replacement. I didn't want a third Garrett.
Brian
Old Jun 9, 2015 | 11:29 AM
Bordeauxman
NPCCPARTSMAN,
My ECT/EOT deltas are not a problem. Even when hauling 16,000 pounds total up hill on the interstate deltas were not over 8-10 degrees. The oil cooler and egr are ~ 3,000 miles new. The rig has 103,000 miles total.
Old Jun 9, 2015 | 09:24 PM
firedaniel's Avatar
firedaniel
I had a similar issue only when towing my rv. The turbo needed to be taken apart and clean the vanes and unison ring. There is a youtube video about how to do it. It was pretty easy once you get the turbo out.
Bad Brad
6.4L Power Stroke Diesel
Jun 17, 2014 01:12 PM
dakotaford
May 21, 2012 11:06 AM
BC Powerstroke
Mar 30, 2008 04:26 PM
pacampora
15
Dec 23, 2007 12:48 PM
jackstruck
Nov 11, 2005 01:00 PM
